Home > For Sale & Wanted > Drivers Side A-Pillar Trim
kriswilson
Scotland 2007 Range Rover Vogue SE Supercharged Java Black
After trying to DIY the fix for the blocked sunroof drain today i discovered, no its not behind the external trim and yes they can spilt... Big Cry
have emailed Dan to get a price but if anyone has one spare... Whistle
Post #89463 29th Oct 2011 9:53pm
Have a look under your side sill, is the leak on the side the air suspension reservoir is fitted? If so, we have found the tube from the sunroof is sometimes pinched by the air reservoir... The facelift FF has a larger reservoir than previous model, hence the problems...
Hope this helps...
Craig Thumbs Up
Post #89466 29th Oct 2011 10:02pm
kriswilson
Cheers Craig, i did crawl under and have a look but cant see anything even resembling a drain hose.
I'll have one last look tomorrow before i admit defeat and get it booked into the local dealer. Thumbs Up
Post #89475 29th Oct 2011 10:59pm
I'll put a small bet on with you its the drain tube... Have a good look, we've done approx 15 2007 onwards FF's with water leaks all down to the air reservoirs...
Craig Thumbs Up
Post #89480 30th Oct 2011 12:02am
kriswilson
Well Craig looks like your right..
Any hints on how to free it? Seems like is meant to be routed that way (ie down the top of the compressor and out towards the front mudflap)
Post #89498 30th Oct 2011 12:13pm
daveo
lets have some photos Shocked V8 facelift Range Rover Autobiography 22" wheels.
Post #89525 30th Oct 2011 6:24pm
kriswilson
Dave - Will take photo's tonight when i get home.
Found the service bulletin descirbing the problem so may try going through that to see if i can fix it again. Whats the worst that can happen right Whistle
On a side note, I just went to the local main dealer and he quoted a minimum of 4 1/2 hrs labour to do the job. Suffice to say i declined.
Post #89662 31st Oct 2011 1:27pm
