Home > Technical (L322) > Park Heater fault - help needed...
A1GSS
Right, I've got my IIDTool and plugged it in and read the HVAC fault code...
41 - Park Heater Message Disturbance Fault, it tells me.
Have cleared it a few times and retried the heater, fault comes back. Symptom is that that fans run for a few minutes but the heater doesn't fire, then the fans shut down. Same sympton whether you use the Remote Control or the Timed Climate settings on the screen.
Any ideas? Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #89643 31st Oct 2011 11:18am
A1GSS
Update.
Have now tried every possible combo of reset, fire, trip, remote, reset, whatever, no joy. I give up... Big Cry
Unless anyone has any bright ideas I need an independent expert to look at it. Graham
____
Post #89702 31st Oct 2011 5:19pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Probably being stupid but doesn't the temperature need to be pretty cold before the Fuel Burning Heater fires up? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #89706 31st Oct 2011 6:15pm
A1GSS
I did look this up.
Needs to be 16 degrees or under for the cabin heater, which it was - it was in fact 15 degrees. I assume that the cabin heater ECU reads the external temp as displayed on the cabin screen, rather than figuring its own (different) reading out, but there may be something in it, I'll try tonight once its gotten under 10 degrees. Graham
____
Post #89708 31st Oct 2011 6:20pm
i think the outside temperature has to be below a certain level before the FBH kicks in, and not the internal temp... ... - .- -.
Post #89714 31st Oct 2011 6:50pm
A1GSS
Yes, sorry I wasn't clear. I meant the "Outside Temperature" as displayed on the cabin screen, has to be 16 degrees or less, which it was so I;d expect the heater to start.
It's got a fault which I can clear with my new toy, but it comes back again. Graham
____
Post #89715 31st Oct 2011 6:53pm
Mine has been working at temps for the last few months when i try it, as even when the temp is above the fans kick in to air cool the cabin or vent to atmosphere, the heat that can build up inside the ffrr Smile
Have you checked to ensure the heater is getting fuel or thought about sourcing a unit from a scrapper and see if it will just plug in?
Post #89720 31st Oct 2011 7:16pm
A1GSS
TBH I don't even know where the heater is. It's buried somewhere in the bowels of the engine bay. The Disco one is easily seen and accessible... Graham
____
Post #89731 31st Oct 2011 8:21pm
rayc
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
Possibly the glowplug?
I had a similar issue with an aux heater on, dare I say, a Galaxy diesel Embarassed , Changed the unit's glow plug and all was fine.
Then the head gasket went! Rolling Eyes 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
99 Model 2.5 DSE Rioja Red / lightstone
97 BMW M3 Evo Convertible
plus a few more!
Post #89750 31st Oct 2011 9:18pm
A1GSS
How do I tell if it's working... especially as I can't find the FBH... Laughing Graham
____
Post #89758 31st Oct 2011 9:43pm
have you browsed this graham
http://www.fullfatrr.com/wiki/FBH ... - .- -.
Post #89763 31st Oct 2011 9:53pm
The Fbh is located below the battery.
The easiest way to tell if it is working is to lie on your back on the passenger side and feel if warm flue gases are coming out of the exhaust pipe under the car.
Post #89767 31st Oct 2011 10:04pm
A1GSS
Yes, have tried that, defo no gases.
@Scarey, the wiki tells me all of the things that should happen, but doesn't tell me why mine doesn't fire, and doesn't interpret the fault code returned by the IIDTool.... Question , so. I'm better informed, but no nearer a solution. Graham
____
Post #89787 31st Oct 2011 11:43pm
Been looking at this for a friend with an X5. You can put power to pin 1 on the connector and that will fire up the heater to make sure it's working. They quite often seize or something as they aren't used that often. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #89803 1st Nov 2011 9:07am
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
My FBH on the 2007 FFRR Vogue SE failed last winter during the really bad snow in November.
A common failure point, is the glowplug in the FBH, it will try to start with fan coming on but not ignite, this had happened to mine.
It was replaced but still did not function and showed similar symptoms to those you describe - fans come on but no heat. FBH fires up momentarily then dies.
Guava had the car for several days and corresponded with LR technical. It transpired the HVAC system is a BMW system (likely the same as an X5 as they have a few common components). LR terminated the technical support agreement with BMW in 2009/10 including software mods, it was a software issue on mine. However LR developed a patch which was downloaded to my car and the FBH operated as per normal. Thankfully this was all done under warranty otherwise it would have cost thousands given the workshop time, the FBH replacement part was £1200 alone.
It was finally fixed in early this year after all the snow had finished, I had many cold trips to work as the engine takes ages to warm up if the FBH is malfunctioning.
A main dealer with tenacity will sort your issue out, but it will be costly if there is no warranty. 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #89939 1st Nov 2011 10:34pm
