Home > Technical (L322) > Whats the easiest way to get a secondary key for my pre-05 |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Buy a second hand bmw key, and buy a shell with a blank blade (both on ebay). Get the blade cut to match your car, and take the innards from the secondhand key, and insert in the shell. Hey presto! Range Rover-less at the moment - Pining! |
20th Nov 2011 10:51pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
arrr, not quite that easy, yes the above post is correct but you will need it to be coded, now range rover wont code a bmw key unless you know some one, the pre 05 range rover key uses a Phillips PCF7930AS Transponder chip
20th Nov 2011 11:07pm |
Shropshire lass Member Since: 03 Oct 2011 Location: Shropshire Posts: 58 |
I too had this problem, I went down the main dealer route. However it's definitely worth phoning a few to compare prices as I found they varied quite alot. Also they all charged different amounts to then code the keys . I know there is a means of coding them yourself but when youve just bought a new one you want it to work! |
21st Nov 2011 12:00am |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 |
Can it be done remotely or will the vehicle need to be present?
21st Nov 2011 12:27am |
magicbob Member Since: 03 Jul 2011 Location: Perth Western Australia Posts: 157 |
I purchased 2 new blanks from the bay of fleas, had the key cut here in Perth WA, inserted the old electronics.....yew bewdy!!!worked first time, no problems.
21st Nov 2011 9:27am |
21st Nov 2011 9:36am |
The car would need to be present to code a brand new key I believe. however it may be possible from some of the articles I read to code the key yourself . Think it depends on vehicle age. I'm sure someone more learned will appear to help you. |
21st Nov 2011 10:31am |
Programming a new Key
21st Nov 2011 10:39am |
As above! Exactly! I forgot to say, for coding you can go to a stealer and get ripped off, or you can do it yourself in 5 minutes. I very much doubt that the transponder would be any different to that for an e38 7 series. Believe me I'm not handy with spanners, but even I've managed to re-code a key! Range Rover-less at the moment - Pining! |
21st Nov 2011 1:04pm |
So exactly what kind of secondhand BMW key will pass muster in the coding process? Anyone actually done it? Pics? (not picks ) / Links? .
21st Nov 2011 3:50pm |
Hold on there is two parts to coding a key, yes the first part is to open and lock the doors, this is easy and is explained in the previous posts, the second it the transponder chip, this is the part the car looks for to make sure it is the correct key for the car, it is linked in with the ignition and ecu, this coding of the chip in your key can not be done by your self, it will need to be done by land rover or some one who has the coding equipment. i have been looking for some other then land rover to do coding when working on the flip key conversion for the pre 05 cars and as yet i have not found any one. V8 facelift Range Rover Autobiography 22" wheels.
21st Nov 2011 4:37pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
When I asked for a new key at the dealers, I was told that it's delivered pre-cut and pre-programmed, with the info taken from the vehicles chassis number held at LR. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
21st Nov 2011 7:28pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
When I got my new key it was ordered by a non landrover dealer . Key was coded into car MY2008 using an Autologic that my Indie had took about 2 mins. Present :2008 TDV8 HSE
21st Nov 2011 7:38pm |
yes i was told that they can programe and cut a key from your vin number but if for any reason you have had a lock change it wont fit and they will not give you your money back, it wold be nice to find some other then the dealer to get keys dome V8 facelift Range Rover Autobiography 22" wheels.
21st Nov 2011 8:07pm |
