Home > Technical (L322) > CTEK hard wire kits
Page 3 of 4 <1234>
Just wondered how far from the car the Ctek is and how you have connected to the battery.
Post #108247 20th Feb 2012 3:43pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Forgot to say, in the leaflet with the hard wire kit, it says to wait 30 minutes to get an accurate reading, does this mean 30 minutes after turning off each time, porbably to allow for all computers etc to fully shut down (like on the FFRR's for example)
Post #108248 20th Feb 2012 3:47pm
mrblonde
Could anything on the cvar drain a brand new battery in 4 days? And something not noticeable to the eye (e'g' headlights left on)
Thanks again
Post #108249 20th Feb 2012 3:49pm
Plenty of bits on a FF could drain a battery in 4 days.
Ignoring the indicator lights on the charge lead have you tried starting the car.
Also what is the Ctek indicating regarding charge status?
Post #108256 20th Feb 2012 4:20pm
mrblonde
Sorry forgot to say, car started fine this morning, even with the red LED indicator on the CTEK lead
Not too sure what you mean by 'what is the CTEK indicating regarding charge status?'
Do you mean green led = Fully charged, yellow led = partially charged, red led = charge required
Post #108261 20th Feb 2012 4:43pm
Sorry it depends which Ctek you have, mine has battery charge level indicators.
If you car started ok it doesn't sound like the battery has discharged.
Post #108265 20th Feb 2012 4:45pm
mrblonde
Yup thats what mine has, sorry didnt explain myself great reading back through my posts, it shows battery charge level, 3 small flashing lights, kinda like a traffic light
Do you check yours regularly? And does it even flash yellow or red?
Post #108266 20th Feb 2012 4:51pm
No mine just sits on the fully charged indication, green light.
Occasionally if I have the doors open it drops back to 80% for a couple of hours then back to green.
Post #108270 20th Feb 2012 5:00pm
mrblonde
Sad judging by that then i guess i still have my drain issue, even after changing the FSR
bummer
Post #108271 20th Feb 2012 5:04pm
mr blonde, is your obd port hatch open, if so this drains the battery...if its closed then i'll scratch me head again... ... - .- -.
Post #108274 20th Feb 2012 5:20pm
mrblonde
hello again mr scarey
Is my what open? and where may I find my obd hatch please? Embarassed
Post #108287 20th Feb 2012 6:43pm
to the lower right of the steering wheel is the hatch/flap that gives access to the diagnostic port..sometimes this isnt closed properly .. ... - .- -.
Post #108290 20th Feb 2012 6:45pm
mrblonde
Thanks scarey
I wil ltake a look tonight when I get home.... In the mean time, can you please scratch your head a little more as mine is already bald as a coot from pulling all my hair out Big Cry
Post #108294 20th Feb 2012 7:02pm
Laughing
thats why i cut my hair short... ... - .- -.
Post #108335 20th Feb 2012 10:44pm
mrblonde
well please grow it back scarey please as the issue is still there I think..... and the OBD port is fully closed Big Cry
If my alternator wasnt charging fully, how would that be tested/measured?
Post #108636 22nd Feb 2012 4:15pm
Page 3 of 4 <1234>
