![]() | Home > Technical (L322) > CTEK hard wire kits |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Are you charging the car in a garage or outside? |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
What connection is on the lead of the charger you have? |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Charging outside gents
What I've got is a mains cable, 5A lighting 2 core circular cable fed from an outside water-proof socket on the garage wall, with a 13A rubber socket fed into the car thro a door opening at the bottom and the door closed on it. In the car, charger plugged into the rubber socket, and then the charger plugged into the front cig socket. Mines a ctek but you could buy this
cheers nicedayforit
I'm assuming like me you are going to put the charger in the car out of the weather and run a mains cable extension lead to the car.
SparkyPhil Member Since: 29 Oct 2011 Location: Staffs Posts: 59 ![]() ![]() ![]() |
I dont want to to tread on anybodies toes, but if you are making you own extension cable/lead I would really recommend that you use 3 core flex with a csa of 1.5mm squared, so the extension cable/lead may and can be used safetly on other eletrical items when necessary. I know this sounds a bit over the top for a small battery charger but if someone else uses it for some other electrical item it could end in tears. If you need any advice/info on anything electrical pm me and will be happy to help
I would agree with you the only trouble is the mains cable needs to pass thro the door seals to use as described.
This I totally agree with but I have had the what if's beaten into me over the years, so I now air on the side of caution all the time. All the best Phil |
Why not keep the charger inside the building and extend the 12v side of it |
I tried that initially but the charger kept going to "error". Don't know why but as soon as I went to option B no problems.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2074 ![]() ![]() ![]() |
Volt Drop? ![]() |
Just been thinking about the volt drop.
