![]() | Home > Technical (L322) > FBH Remote Pairing |
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 ![]() ![]() ![]() |
My FBH remote (T90) wasn't pairing, even after replacing the batteries.
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
It sounds like your receiver unit is attached to the wrong side of the fuse, so it is always live. |
My old one a 06 TD6 paired fine by removing the fuse but my new one an 08 Supercharged you must remove the power lead to the receiver so I suspect something happened to the wiring after the introduction of Terrain Response . 2008 MY Supercharged
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
Yea, tried the fuse 59 method and no luck. Should have said its a Vogue SE TDV8. Looked in both sides, plenty of RF and other module but I haven't seen anything with Webasto label.
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 268 ![]() ![]() |
This is a new device on later models which also heats your soup. ![]() 2012 4.4 TDV8 Westminster - gone! 2007 3.6 TDV8 Vogue - gone! 2003 4.4 V8 HSE (LPG) - gone! 2018 F-Pace 25t Portfolio 1974 LR Series III Lightweight FFR 2014 BMW 640i Gran Coupe |
[quote="JW911"]
This is a new device on later models which also heats your soup. ![]() ![]() ![]() just saw that , but then I am quite hungry right now . 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis Last edited by axle on 7th Dec 2012 8:30pm. Edited 1 time in total |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
just make sure that your battery is in good condition if you are using the FBH!! half an hour is an long time and the dead mans click is very depressing!! Current: TDV8 (3.6) RRS HSE
