Home > Maintenance & Mods (L322) > led upgrade |
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 |
Can you post a link for thos ones Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
16th Mar 2012 9:33pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
Just thought I'd share these photos. The white LEDs are much better fresher and newer looking.
12th Apr 2012 12:39pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
nice find, will have a set of them, V8 facelift Range Rover Autobiography 22" wheels.
12th Apr 2012 10:00pm |
I tried loaded 501 led bulbs in the puddle light but they wouldn't work... |
12th Apr 2012 10:20pm |
Loaded? As in LEDs with resistors? |
12th Apr 2012 10:38pm |
simon, what mirrors are they pre 05 or 06 onwards V8 facelift Range Rover Autobiography 22" wheels.
12th Apr 2012 10:40pm |
Its a 2007 tdv8
14th Apr 2012 2:26am |
Loaded-(What I mean is with the resistor attached to the bulb) |
14th Apr 2012 2:28am |
It's a strange one alright, i also tried LEDs with built in resistors, puddle lights only place on the car that they won't work on.. |
14th Apr 2012 11:57am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
How the hell do you change the bulb in a 2007???? I used search on here and found the pre07 pics, even the bloody handbook skips replacement! Land Rover Addict
14th Apr 2012 12:09pm |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 |
Is the boot lamp a 42mm festoon bulb? Have looked in handbook but it only states wattage and shows a festoon bulb but doesn't give a size.
17th May 2012 9:31pm |
I don't know the exact measurements, but 39mm worked for me. If festoons dont fit exact there is usually a little give in the connectors in that u can squeeze them tighter or open up wider. |
17th May 2012 10:05pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6668 |
^^^^^^ What he sez! The festoon bulbs fit in between 2 pieces of metal with a hole to take the tip of the end of the bulb. If the LED bulb is slightly smaller, just bend the metal contacts in a bit.............. Got - 2017 SDV8 Autobiography in Loire Blue
17th May 2012 10:11pm |
Thanks to all contributors to this thread, very useful and i've just ordered lots of LED's for my car...
17th May 2012 10:18pm |
