Home > Technical > iBus + Resler Interface + Navcoder
Page 1 of 3 123>
dan_uk_1984
For those interested, as you'll know a few months go I bought the Resler Interface. But I was moving house, then xmas happened etc so not had a real chance to have a play with it.
I connected to the CD Changer iBus wire - but an iBus feed is easier to find in the boot. (see info on Resler website) You only need the one iBus wire, and then any ground wire. I used a multimeter to find a handy one.
Hopefully the following should show you exactly what pins to use:
iBus:
Ground:
I've just noticed that NavCoder has a feature to input manual iBus codes:
I'm a sucker for things like this, basically you stick in a code and press transmit and it will do whatever function.
For Example:
3F 06 00 0C 01 31 01 04 driver side mirror fold in
3F 06 00 0C 01 30 01 05 driver side mirror fold out
3F 06 00 0C 02 31 01 07 passenger side mirror fold in
3F 06 00 0C 02 30 01 06 passenger side mirror fold out
3F LL 00 0C 05 00 CK // Move Driver Seat forward
3F LL 00 0C 05 01 CK // Move Driver Seat Back
3F LL 00 0C 00 0B CK // Toggle Locks
3F LL 00 0C 00 08 CK // Open Trunk
3F LL 00 0C 00 02 CK // Activate the Window Washer
3F LL 00 0C 00 10 CK // Simulates Driver Door Open
3F LL 00 0C 00 11 CK // Lights on for 3 seconds then dim
3F LL 00 0C 00 14 CK // Wiper, single swipe
3F LL 00 0C 00 15 CK // Wiper, two swipes
3F LL 00 0C 00 16 CK // Wiper wash only (no wiper motion) about 2-3 seconds
3F LL 00 0C 00 40 CK // Open Trunk
3F LL 00 0C 00 41 CK // Rear Doors Locks ON
3F LL 00 0C 00 42 CK // Rear Doors Locks OFF
3F LL 00 0C 00 43 CK // Open the Gas Lock
3F LL 00 0C 00 44 CK // Lift the Rear Drivers side Window
3F LL 00 0C 00 45 CK // Lower the Driver side window
3F LL 00 0C 00 46 CK // Close the Gas LOCK
3F LL 00 0C 00 47 CK // Lower the Rear Passenger side window
3F LL 00 0C 00 4B CK // Washer Only
3F LL 00 0C 00 51 CK // ALL Locks Off
3F LL 00 0C 00 55 CK // ****** Alarm ON! **** Careful LOUD!! ****
3F LL 00 0C 00 59 CK // Interior Lights off
3F LL 00 0C 00 5B CK // Flashers ON (Interior lights too)
3F LL 00 0C 00 64 CK // Both Rear windows Down
3F LL 00 0C 00 65 CK // All windows DOWN
3F LL 00 0C 00 66 CK // Open Sunroof
Post #14539 8th Mar 2010 9:01pm
noddy
United Kingdom 2002 Range Rover Td6 Vogue Auto Zermatt Silver
Why would you want to do that? 02 Vogue
Post #14584 9th Mar 2010 3:46pm
dan_uk_1984
Because it's the precursor to programming your own functionality and changing dealer spec options.
Post #14592 9th Mar 2010 4:15pm
noddy
oh, ok. Can i make my doors lock when I drive off using this then? 02 Vogue
Post #14604 9th Mar 2010 4:35pm
dan_uk_1984
Yes, if you can figure it out.
Post #14618 9th Mar 2010 7:56pm
M44K TS
I've just used the USB interface lead with Navcoder and sucesfully enabled tv in motion, had a bit of an issue with my laptop saying com3 was in use but managed to get round that. Seems like a good bit of kit. 2006 Mercedes CLS
1991 Retro-style Mini
1998 Escort GTi Winter Steed
But really finding it hard to fight the urge for a S/C...
Post #15023 17th Mar 2010 9:39pm
View user's profile Send private message Reply with quote
dan_uk_1984
Where did you take your iBus feed from in the end?
Post #15028 17th Mar 2010 10:06pm
M44K TS
Just plugged it in line with the TV Tuner, connected straight away once I got the laptop sorted. 2006 Mercedes CLS
Post #15031 17th Mar 2010 10:39pm
dan_uk_1984
Just remember next time you plug it in it should go into the same USB port, if you put it in a different one the system will assign it a new com number. Not a problem as long as you connect it all up and THEN open Navcoder it should auto detect which com port to use.
D
Post #15032 17th Mar 2010 10:41pm
M44K TS
Yeah cool, I'll remember that. I'm gonna have a play around tomorrow after work. 2006 Mercedes CLS
Post #15034 17th Mar 2010 10:55pm
Tesh
United Kingdom 2004 Range Rover Td6 Vogue Auto Java Black
Ive just recieved the Resler Interface and paid for Navcoder and can I hell get it to work
Feel like chucking it in the bin!!! Big Cry Big Cry Evil or Very Mad Evil or Very Mad
Post #15707 26th Mar 2010 7:43am
dan_uk_1984
What wire are you using to get the iBus? CD Changer or in the boot?
Describe the problem...
Post #15709 26th Mar 2010 8:14am
Tesh
I have fitted an intravee and Alpine ipod controller so its easy enough to get to the ibus lead in the glovebox
Now Im attaching the plug on the end of the loom directly into the Resler USB but Navcoder does not detect the ibus.
Im running Vista and have downloaded the correct drivers
Thanks
Tesh
Post #15710 26th Mar 2010 8:32am
dan_uk_1984
Are you using two wires or three?
In theory one should use iBus, 12v+ and 12v- However that wouldn't work for me, so I just use iBus and 12v-
You checked the photo's above for pin config?
Have you told iBus the correct com port to use? In device manager you should have a com port and a number...
You should aways plug the resler into the laptop before opening up navcoder...
Dan
Post #15711 26th Mar 2010 8:37am
Stebo
2003 Range Rover 4.4 V8 Vogue Auto Giverny Green
I've got this kit and found it pretty straight forward, did manage to blow a few fuses tho Whistle
I connceted it up to one of the wires in the boot, took all of 30 seconds. Uncliped one of the plugs, ramed the navcoder wired into the appropriate holes and reconnected the clip. Had the same issues with COM3 being in use, etc but when I changed the USB port everything was fine.
My car is up for sale, I'll take this out of it and sell it to anybody who is interested, the navcoder program is £20 to download though.
Post #15712 26th Mar 2010 8:54am
Page 1 of 3 123>
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2012 Martin Lewis
