Home > Maintenance & Mods (L322) > Finally sorted a few "jobs" on my 2003 TD6 ! |
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 |
Plenty of room to poke around now
29th Apr 2013 7:44pm |
All injectors came out with only the slightest "tap" to loosen em
29th Apr 2013 7:45pm |
(This was 21:30 Friday night !!!!!)
29th Apr 2013 7:46pm |
Aspin83 Member Since: 22 Apr 2013 Location: Blackpool Posts: 18 |
wow some amazing work looks well towing the trailer too, do the td6 have the swirl flap system as per the bmw 530 diesel engine ?? |
29th Apr 2013 8:02pm |
Thankfully no swirl flaps were on my TD6 and I am led to believe no TD6 Range Rover has the pesky little blighters fitted - lol |
29th Apr 2013 8:10pm |
that's good I had to do a full engine rebuild on a 530d as a swirl flap decided to let go in the cylinder lol looks well though |
29th Apr 2013 8:27pm |
swirl flaps is a common fail on the 3.0 D |
29th Apr 2013 9:07pm |
yeah and a expensive one too ha ha hence why I went for a s/c RR, was unsure weather they had the swirl flaps [/img] |
29th Apr 2013 9:20pm |
Flaps were only fitted to the auto boxed bmw's and nothing else from what I know
29th Apr 2013 11:03pm |
Not sure at all but even with the amount I removed from the engine/bay the HP pump was still well hidden away How has a faulty HP pump been diagnosed ? |
29th Apr 2013 11:15pm |
Fuel rail isn't getting upto pressure and then spits out an error code and it won't fire without some easy start or such to get the engine upto tick over quickly as I'm guessing the pressure is too low also the glow plug relay is throwing a fault code so need to check that as well but it was showing 28,000(approx) kpa on diag for fuel rail pressure when last fires up so not 100%.
29th Apr 2013 11:25pm |
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 |
Whats a swirl flap please?
30th Apr 2013 2:03am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
swirl flaps,
30th Apr 2013 6:53am |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
K&N's come with jubilee type clip Bofa Mine was a blue one! |
30th Apr 2013 8:14am |
