Home > Maintenance & Mods (L322) > How to change those pesky $%^& rear calipers on a TDV8. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34920 |
great how to.. wiki'fied. ... - .- -.
30th Jul 2013 10:09pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Present :2008 TDV8 HSE
30th Jul 2013 10:13pm |
GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61 |
Why didn't you change the carrier as well? |
3rd Aug 2013 7:56am |
Because it doesnt come as part of the caliper kit, and there are pretty much no moving parts bar the sliding pins. Dead easy to swap over just two more bolts, but didnt see the point, when the dealer swapped my caliper the other side they just changed the body.
3rd Aug 2013 8:32am |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
Remember to road test slowly at first and try a few stops within 100m of your house. If you've cocked up the bleeding you won't want to discover it at the first junction you come to
3rd Aug 2013 10:29am |
Think my rears need doing, squeeling and a lot of heat on the rears after a journey.
10th Aug 2013 6:12pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
You can paint them in a zinc paint before you do the job... Lasts for ages take the caliper carrier off, wire brush it & paint that too
11th Aug 2013 5:46am |
Use ukpas25 for 25% off on ecp.
11th Aug 2013 4:23pm |
Would have done both mine Craig, but the MD did the other one only 6 months ago, i could have had this one done as well but was going away in the car and needed it asap. Next time it will be both and the discs. There is nothing that can't be fixed with a hammer😜😜
11th Aug 2013 4:25pm |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 |
I had the same on one of my rear pads when I replaced it. It was tight in the carrier and squealed badly when it warmed up.....seemed to jam. I eased the lugs just a tad on the top and bottom of the pad with a file which allowed it to slide more freely.... heating and squealing fixed. 2007 TDV8 Vogue SE Java Black |
12th Aug 2013 6:53pm |
Did that on mine when i swapped them for the mot last year.
14th Aug 2013 10:16pm |
Changed them over the weekend, easy job really.
19th Aug 2013 9:38pm |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 |
can i confirm that no 'computer' reset has to be done because of the electric hand brake? 2011 4.4 TdV8 Nara Bronze |
20th Aug 2013 1:45pm |
You don't touch the handbrake when changing the callipers.
20th Aug 2013 10:39pm |
