Home > Technical (L322) > Cannot find source of battery drain |
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 |
Have now carried out 4 "fuse-pulling" tests trying to find the source of a battery drain, but to no avail
20th Sep 2013 9:26am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
is the OBD port flap closed? ... - .- -.
20th Sep 2013 9:29am |
Hi Stan
20th Sep 2013 9:35am |
20th Sep 2013 10:24am |
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 |
Without meaning to sound stupid,why would that make a difference. ?? |
20th Sep 2013 10:29am |
if you have a look at the OBD you should see some contacts..when the flap is open some ecu's are still awake and this can cause a battery drain... ... - .- -.
20th Sep 2013 10:48am |
Thanks Stan, i am off out to check mine right now. |
20th Sep 2013 10:53am |
A good idea but it would be great if I could identify the source of the problem. The battery is back on charge so I'll check the voltage again tomorrow and see if it's still draining. Fingers crossed! Cheers
20th Sep 2013 1:36pm |
Al ajv8 Member Since: 19 Apr 2013 Location: middlesbrough Posts: 20 |
Out of interest what is OBD ? |
20th Sep 2013 1:55pm |
on board diagnostics.. ... - .- -.
20th Sep 2013 1:57pm |
Well, some good news. The reading is now down to 0.140mA from 0.200mA, so closing the OBD flap seems to have helped. But there is still something drawing at least 0.1A and I need to find it!
20th Sep 2013 3:48pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
When you say you have pulled all the fuses have you pulled the 50A Maxi fuses on each fuse board as well? |
20th Sep 2013 4:13pm |
Yep Cheers
20th Sep 2013 4:23pm |
You need to test down thro the alternator.
20th Sep 2013 4:41pm |
