Home > Technical (L322) > 12v Sockets / Cigarette Lighters not working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
it still points to a fuse problem i think, not sure if theres another one somewhere.. ... - .- -.
10th Mar 2014 12:12pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
That was my thought but couldn't find any mention of other fuses in my handbook. There is a difference between knowing your sh!t and knowing you're sh!t
10th Mar 2014 12:24pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
There's one in the rear load space fuse box . Fuse 17 or 18 (20amp) that's worth checking. Page 261 of my handbook. Paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
10th Mar 2014 12:28pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Check fuse No. 1 in the rh rear loadspace fusebox, it's a 20amp fuse for the cigar lighter/socket. That one is the most likely culprit.
10th Mar 2014 2:47pm |
Thanks for the clarification discotigger..must have changed to 17/18 on the 2007MY. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
10th Mar 2014 3:50pm |
I have checked every fuse in the glovebox and the boot and none blown. Have swapped those in pos 2 in the front & pos 1 in boot with others and still no power to either socket. Front socket works fine. Also PURE DAB which was linked into wiring for cubby box socket not working. I have tried difference plugs which work in the front socket just to rule out plug faults. Any other ideas? There is a difference between knowing your sh!t and knowing you're sh!t
10th Mar 2014 4:00pm |
No worries paulmoran2
10th Mar 2014 4:08pm |
10th Mar 2014 4:09pm |
When the PURE DAB was wired in to the cubby box, did it have a separate in-line fuse? If so, that could be the one that's blown. Or possibly even shorted a cable? |
10th Mar 2014 4:22pm |
To rule out the DAB I have disconnected it although the fuse between the original wiring and the control box is fine and double checked before disconnecting with a new fuse. Was fine until USB put directly into rear seat socket, DAB was working and accessories plugged in to cubby socket so must be linked to a fault or fuse somewhere but have checked every one I can find. There is a difference between knowing your sh!t and knowing you're sh!t
10th Mar 2014 4:47pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
I has a similar issue a while back when changing to LED bulbs. I managed to short one out and all the rear interior lights went out. Checked every single fuse to no avail. Left the car overnight and lo and behold, the next day all was well.
10th Mar 2014 5:14pm |
Are there any other fuses apart from the ones in the glovebox and right rear that could affect the 12v sockets. Front and boot socket working fine. If not a fuse what else could knock out the 2 sockets and as far as I know nothing else? Quickly starting to fall out of love with the FFRR and my eldest daughter who appears to have broken it! There is a difference between knowing your sh!t and knowing you're sh!t
10th Mar 2014 5:54pm |
Been looking through the electrical circuits handbook, it could be the wiring. The rear cigar lighter and cubby accessory sockets are spliced off the same circuit that comes off fuse 1 in the rear compartment. It's possible that the wiring has burned out or got broken when the usb connector shorted out the circuit. I would also check the connectors on the sockets as well, but that means a bit of dismantling.
10th Mar 2014 6:32pm |
Thanks, I have tested the socket from the cubby on the front wiring and works fine. The PURE DAB only had a 3 Amp fuse so not much power and that fuse had not blown either. Is there anything else on Fuse 1 in the boot that shouldn't work and where does the feed for the two sockets separate from the rest of the circuit. Any idea where the wires run (assume from rear fuse box to centre cubby section)
10th Mar 2014 6:54pm |
