Home > Technical (L322) > 2012 led headlights not working SOLVED!
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
Just realised tonight that the led lights on my 2012 facelift are not working. They were working fine?
On sidelight nothing on front but rears fine, on normal the main beam and high beam work? Same on auto setting
Any ideas?
Post #272670 24th Jul 2014 8:23pm
not familiar with your year but is there any thing in the menu? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #272671 24th Jul 2014 8:24pm
winslo
Its a 2006 supercharged but had the conversion done
Post #272673 24th Jul 2014 8:32pm
ah, might be a loose wire then...have the drls switched on and fiddle with a few wires to see if one is loose.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #272679 24th Jul 2014 9:40pm
its me
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Re: 2012 led headlights not working
Unnecessary quote removed
I have exactly the same problem. Looking forward to you finding the fault because I failed to do so. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #272726 25th Jul 2014 8:16am
Who converted your cars? Cant you take them back?
Post #272728 25th Jul 2014 8:42am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Winslo
Each conversion specialist could use a different method to power the lights (direct or relay fed) but here's a diagram that one of the forum members (credit to
mattstevenson2005) put up when he undertook his diy conversion that may help..I obviously cant say this is how yours is, but it may point you in the right direction when testing with your multi-meter...good luck.
ADDED- Apologies. This diagram is for a 2003 to 2010/12 so not sure if the 2005 headlamp connections changed-others may know Whistle
 GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #272731 25th Jul 2014 9:14am
winslo
hi my car i believe was converted by DCC
They were working fine, however i had the car LPG converted a few weeks ago and yesterday was the first time i actually tried the side lights as my lights are always on auto.
Im now beginning to think the lpg installer may have chopped a wire or something?
thanks
Post #272733 25th Jul 2014 10:06am
winslo
SOLVED the problem!
Took cover off fuse box under engine. Removed the lpg ecu which looks like it has been wedges in there and there was a fuse with only 1 side attached to the end, found the loose wire connected it
and now we have light!
Stupid gas fitter!
Cheers all
[/img]
Post #272873 26th Jul 2014 9:51am
paulmoran2
Great result!! Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #272878 26th Jul 2014 11:11am
