Home > Maintenance & Mods (L322) > Knocking. Front Drop Link Replace & Freeing Seized Nuts |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Give it enough of a bash and it should shift, or get more leverage on it if you can, get some heat on it (serious heat), otherwise
19th Sep 2014 3:20pm |
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 |
Heat it with a blow torch till it glows then give it a go with the spanner , if the nut has rounded you can get a rounded nut remover which will grip it , or as I had to do on the wife's mx5 drop links cut through with a grinder or powered hacksaw . |
19th Sep 2014 3:22pm |
Or go for the mk1 hacksaw and elbow grease as per joe 90's pic |
19th Sep 2014 3:23pm |
Thanks. Manual hacksaw methinks based on my limited arsenal of tools.
19th Sep 2014 3:58pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
When I did mine I did one side at a time. To take strain off bottom Link I put a bottle jack under fitting and jacked it up slightly enough so that there was a bit of slack in the link so it was easy to remove. Present :2008 TDV8 HSE
19th Sep 2014 4:30pm |
Did mine with wheels on on the ground Ryan.
19th Sep 2014 7:16pm |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
try a nut spliter have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
19th Sep 2014 8:08pm |
Thanks all for a really helpful response. Will goto the lubricant/ heat method (need to by a blow torch unless a hair dryer will do it
19th Sep 2014 8:24pm |
Air wrench will remove it |
19th Sep 2014 8:44pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
I don't mean to state the obvious sir, but it sounds like you need some bigger/better kit! If your going to attempt these tasks then you really do need to invest some of them savings your making into some quality tools sir
20th Sep 2014 12:44am |
20th Sep 2014 6:50am |
So I listened to the comments and took Craig's sound advice on board, adding some tools and kit to my existing kit and here's what I bought, all to free one M12 Hex nut (accepting that items bought will be a longer term investment)!
24th Sep 2014 10:58pm |
The breaker bar was no use by the time I'd bought the new tools and kit to tackle the seized driver's side lower Hex flange nut to the ARB drop link because I'd already partially sheared the nut using a 12 point socket and ratchet (12 point socket is no use for seized nuts like this as the socket just spins under heavy load which can damage the outer nut).
24th Sep 2014 11:17pm |
Nice damage
25th Sep 2014 12:55am |
