Home > General > Looking to buy... Budget? |
MattChaloner Member Since: 12 Oct 2014 Location: Corsham, Wiltshire Posts: 52 |
Hi all, I'm Matt, and I'm new here, having previously had a few other LR products... Freelander, P38 RR, Disco 300tdi x2 and a disco TD5...
14th Oct 2014 9:47pm |
Hi Matt,
14th Oct 2014 10:10pm |
Thanks for the reply. I think it's the 3.0 diesel I'll be looking for as opposed to the newer variants. I'll take a look at the wiki, thanks |
14th Oct 2014 10:12pm |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 |
I had a nosey through what's been for sale on this forum over the past few months and these 3 were in or around your budget.
14th Oct 2014 10:32pm |
If you do a lot of miles in the 116 then doing them in the FF is not going to be cheap. I'd budget your running costs being double or triple at least if you work on a avg MPG in the FF of being around 24-26mpg.
14th Oct 2014 10:58pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
You're looking at the cheaper end of the market. No problem with that. But the car you get wont be perfect. If you're handy and can do some work yourself, you'll save some money. At that age and $, have you thought of the BMW petrol with LPG? |
15th Oct 2014 2:20am |
Kingpleb you're spot on, I do get around 50 to the gallon and have budgeted for fuel and tyres etc to be around double the cost
15th Oct 2014 8:44am |
Reliability wise as long as it's been serviced well it should last as long as the td6 if not longer due to the cleaner burning nature of lpg. Although if check the plugs that are in it are of a colder running grade to help get the best from it.
15th Oct 2014 10:27am |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2283 |
Hi Matt
15th Oct 2014 8:42pm |
zoso Member Since: 20 Aug 2014 Location: Ayrshire Posts: 79 |
Hi Matt
16th Oct 2014 12:31pm |
woodchip Member Since: 19 Apr 2012 Location: cumbria Posts: 132 |
Sorry to dampen your desire to own a FF, but if I was traveling between 4 counties and using it for work with a budget of £6500 in all honesty I wouldn't buy a FF. Not sure what I would buy, but I can't feeling that where you are now is a good ish choice as any. And yep I have a FF and don't like bm's .any of them.
16th Oct 2014 7:05pm |
Thanks all for your messages.
16th Oct 2014 7:45pm |
I see 122 k miles as High mileage (which my 02 has done). I know, from previous discussions on here, others do not. The advantage of an older car at 6k£ is, that you wont lose much on depreciation.
16th Oct 2014 8:12pm |
To be honest mileage isn't that bad as long as it's been looked after in its life. Yes suspension will be a bit more worn but the rubbers are getting old anyway.
16th Oct 2014 8:24pm |
