Home > Maintenance & Mods (L322) > Sticking caliper? Fix or replace?
Page 2 of 3 <123>
Dealer price per calliper is £345.50 each! Discovery 4 HSE
Post #303370 7th Jan 2015 2:10pm
pld118
Are the 5.0 rear calipers TRW?
If so and if AF do the caliper you want, I can vouch for their caliper service.
In truth, being cynical, at the outset I thought "bet they find a reason not to refund me for my old calipers". Not at all.
I packaged them in the new caliper box supplied by AF, went to the post office, sent my old ones to AF and within a couple of days, the money was back in my account for the refund reference the returned old calipers.
Completely trustworthy and efficient service.
Post #303374 7th Jan 2015 2:20pm
Wonder how much a rebuild kit is from Brakes Int... Cant be more than £30 a side surely! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #303376 7th Jan 2015 2:27pm
Yep, according to AF they are anyway. Discovery 4 HSE
Post #303422 7th Jan 2015 4:57pm
IS it different to the ones on the TDV8 then? or is it just a TRW like the rest...... If so they are available from most local motor factors, I got a refurbed trw one for mine from ECP and another from a local factors after the ECP one stuck on again...... the second was refurbed by brake engineering. Still about £60ish.
But yes do both!
edit - no they are different TRW callipers...... LR015581/83 5.0sc There is nothing that can't be fixed with a hammer😜😜
Post #303428 7th Jan 2015 5:43pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Are you sure it's not a badly adjusted handbrake after refitting the new discs and pads ? I'd be amazed if the calipers on your 5.0 Supercharged were fooked already.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #303472 7th Jan 2015 7:55pm
I've just spent an hour reading and searching old threads. Lost count of the numbers of people who have had the exact same symptoms, and all turned out to be callipers sticking.
Intermittent heat, vibration, squealing. Discovery 4 HSE
Post #303503 7th Jan 2015 9:56pm
When the other one went on the ff I have the heat was all the time. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #303508 7th Jan 2015 10:11pm
But yes do both!
4.4 TDV8 & 5.0 use 6 pot Brembo's up front and a much larger rear calliper than was on the older 3.6 TDV8 or 4.2 Thumbs Up
Post #303529 7th Jan 2015 11:00pm
pld118
Is it 6 pot caliper front, 4 pot caliper rear... For the 4.4TDV8 & 5.0?
Post #303538 7th Jan 2015 11:20pm
CG-SC
6 pot front, sliding rear.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #303601 8th Jan 2015 11:06am
But is the piston at the rear bigger?
I checked brakes int's website a fit doesn't list it for the 5.0 and 4.4 so I'm betting they are spcial order jobbies either with a larger piston or dual non sliding for them. If they have moved to no ln sliding it would be a design improvement 😄😄😄 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #303606 8th Jan 2015 11:27am
No they are still the same system Will, just bigger! Almost twice the disc/pad area of my old 3,6... Whistle
Post #303609 8th Jan 2015 11:40am
So much for progress Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #303618 8th Jan 2015 12:13pm
If they were fine before the new pads were fitted, could that not be the problem? Could the pad be sticking in the calliper in some way? I've had pads rusting in to the slides they sit in, a quick filing and lubing does the trick, but you have new pads so maybe not. Previously..
Post #303623 8th Jan 2015 12:29pm
Page 2 of 3 <123>
