Home > Technical (L322) > How do the Adaptive light work? |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Still curious. My pre 2006 4.4V8 Vogue did the whole crosseyed thing, my 2006 4.2 and 2010 5.0 did too. This is 2007MY Vogue with Bi-Xenon lamps, so by law (I understand) it should be applying some sort of self levelling? So surely I should see at *some* point a test that it's working? I'm not interested in AFS tbh, I just want to know if my lamps should swivel up and down at least?
4th Feb 2015 5:14pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Yes i believe all AFS models do the test as the ECU is looking for their angles NON AFS i.e. DHL lights don't do the test... I believe |
4th Feb 2015 5:17pm |
Cheers, my only concern being that the 4.4 didn't have AFS, but *did* do a light check..... Land Rover Addict
4th Feb 2015 5:22pm |
This seems to say DHL (Dynamic Headlight Levelling) and AFS are the same thing?
4th Feb 2015 5:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34939 |
2 separate functions but they use the same step motors gary... ... - .- -.
4th Feb 2015 6:52pm |
...or not
4th Feb 2015 9:51pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
I have it Got - 2017 SDV8 Autobiography in Loire Blue
4th Feb 2015 10:32pm |
Alanm_3 .... mine's not an SE, just has DHL listed on the build list Land Rover Addict
4th Feb 2015 10:37pm |
OK been out and checked on a 2006 "55reg" TD6 Vogue WITHOUT AFS and they don't go boss eyed! And i have also checked a 2007 TDV8 Vogue WITHOUT AFS and NO boss eyed again! Checked an 08 VSE and boss eyed
4th Feb 2015 11:42pm |
Cheers Craig
4th Feb 2015 11:45pm |
4th Feb 2015 11:47pm |
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 132 |
Have read all posts relating to adaptive headlight operation, but not grasping it
7th Mar 2015 2:44pm |
