Home > Maintenance & Mods (L322) > V8 viscous fan removal tool |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Halfords do a fan spanner at reasonable rates .
1st Jul 2015 8:25pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
Hadn't thought of them, cheers. |
1st Jul 2015 8:28pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2025 |
if you want to buy 'o' rings, then just measure and go to ebay, and look for Viton o rings, with a typical size near the one you have, and they often have 'option choice' to select the diameter, and thickness. You should really measure the plastic part, less a 1mm each side, to seat. you can pick these up for less than a pound! slip on some vasalene, and presto.
1st Jul 2015 8:53pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
If you’re desperate enough to drive up to Leyland you’re welcome to borrow mine. In fact you can have it for £25, if you'd prefer.
1st Jul 2015 10:05pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Those fan spanners are rubbish, I mean they're ok for some cars that have very tight access, but a normal 32mm spanner is far better on the range rover.
1st Jul 2015 10:13pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7909 |
What firm...?? Pete
1st Jul 2015 10:37pm |
I assume that the OP already has the 32mm spanner, he just needs the holding tool. The holding tool in my picture is the official Land Rover tool LRT-12-215 Phil |
1st Jul 2015 10:55pm |
http://www.dingocroft.co.uk/acatalog/Tools.html
1st Jul 2015 10:59pm |
if you need the tool desperately, you can just make one out of cardboard, poke through the holes with a sharp screw, and wiggle about... and then mark it out on some steel, and grind it roughly to fit, drill the holes generously etc.
1st Jul 2015 11:09pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
I agree, making one would be quite easy, but you'd need a large enough and thick enough piece of sheet steel lying around, which not everyone does.
2nd Jul 2015 8:11am |
nowadays, you never need to have the shed full of steel off cuts, when you can click on your phone, from your garden steam chair. -and let ebay deliver, here
2nd Jul 2015 8:21am |
The original rad did it's job for near enough 11 years, can't complain. The replacement started leaking from down the side where the fins join the main body in just six months. Coincidently, some one else I know had the exact same problem with the same rad after 4 months ,bought from the same place. His went back first and he was told it was caused by electrolysis and that they wouldn't cover under the warranty. When I went back, got the same bull pooh and kicked up a fuss, pointing out that if that was the case, how come the original had lasted so long and why wasn't the heater matrix leaking. Won't bore you with the rest of the conversation but did leave with a replacement rad. Thats lasted nearly 18 months and same problem. |
2nd Jul 2015 9:09am |
What make are the rads your using? I had a problem a few years back on a 5 series BMW where 3 replacement rads leaked, in the end I got my money back and bought a Behr rad which was more expensive but leak free. From now on I only by OE or well know quality brand make rads. I recently put a genuine rad in my RR and it has been fine to date touch wood. |
2nd Jul 2015 12:34pm |
Thank you all for your offers of help. Nut finally loosened today after a night of penetrating oil.
2nd Jul 2015 4:34pm |
