Home > Maintenance & Mods (L322) > Wet Passenger (Left) Side Carpet |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34931 |
i think it was ed china that put a smoke machine inside a car and watched for the smoke outside...this would probably find the leak but i appreciate not every one has a smoke machine in their garage.. ... - .- -.
12th Jan 2016 6:34pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Have you checked the ac condensate drains? |
12th Jan 2016 6:46pm |
Hairball Member Since: 11 Jul 2014 Location: Leicester Posts: 67 |
I had a split pipe for rear washwipe that ran inside car on a bmw x5 dont know about rangies |
12th Jan 2016 7:09pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1227 |
Check the drain holes/tubes for the sunroof are clear. You will find them at the very corners of the drain channel on the sunroof.
12th Jan 2016 8:19pm |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
+1 Its the AC drain there is one on each side. Get under the FF, rubber nipples inside trans tunnel. |
12th Jan 2016 8:21pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
There are two exit points on either side of the car sir... Under the A pillar and under the B pillar... If you poured in water and it only came out of the forward drain, pound to a pinch the rear one is blocked and parking the nose uphill will make the rear one leak into the floor in navy rain... |
13th Jan 2016 12:31am |
Craig,
13th Jan 2016 3:28pm |
Do the sunroof drains work when the sunroof is closed onto it's seal?
13th Jan 2016 4:09pm |
Yes Paul, there are four sir |
13th Jan 2016 6:43pm |
Yes NDFI the drains are made to work constantly (when it rains!) The seal is mainly there to keep wind noise to a minimum... The tray below the glass collects rain water which drips past the rubber seal and sends it down the 4 tubes to the floor, so in essence the sunroof is built to leak and the tray system is built to manage that leak! unfortunately the autumn sends organic matter down the tubes which clogs them occasionally! Hence they block/leak more in the winter... |
13th Jan 2016 6:50pm |
Never knew that.
13th Jan 2016 7:01pm |
The next dry day, pour some water SLOWLY onto the sunroof glass and let it run around the seal. I say SLOWLY so as it does not run past the seal across the roof and drip. Then look under the car and you should see drips under the A pillar & B pillar. Bare in mind, it may take a fair bit of water to get all of the drains draining! And if one is slightly blocked it may take a fair amount of water before it will start to drip
13th Jan 2016 10:45pm |
