Home > Technical (L322) > went in for oil change, came back out with AIR SUSP INACTIVE |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
i had to reset mine about 5 times before it shut up and got on with it.
25th Feb 2016 9:29pm |
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 |
thanks for the advice,
25th Feb 2016 10:36pm |
codes are the key, an air bag can leak at a certain point and then when it deflates to a certain level and the bag folds over itself it can seal the leak again but i would think it is more likely the height sensor doing something daft as you say |
25th Feb 2016 11:12pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7927 |
If you put the ignition on with the front seats out you will need your IID to turn off the resulting airbag light... they are handy little things.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
26th Feb 2016 12:04am |
hi guys, got my IID.
26th Feb 2016 6:39pm |
Yep, go into, oh I wish I could remember... in some setting you can manually raise individual corners, this will disable the EAS so you pump the corners to where you want and can use the FF until you get it sorted...
26th Feb 2016 6:52pm |
Cheers Haylands, i tried upping and downing the vehicle now its all over the place, fronts really high etc and wont come down much!
26th Feb 2016 7:11pm |
The sensors wear out.. I've changed two in the last year... very easy, two bolts one plug...
26th Feb 2016 7:50pm |
Download yourself a copy of the rave manual from the link below, the height sensors are easy to change.
26th Feb 2016 7:51pm |
Thanks Haylands thats much appreciated!
26th Feb 2016 8:31pm |
The IID tool does more than any other tool on the market, including JLR's own one...
26th Feb 2016 8:41pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
As pete says, get an original part, and if you have xenon lights you will need a specific sensor, depending which one you are changing.
26th Feb 2016 8:52pm |
He's lucky Greg, that one that's gone on his is the cheap one...
26th Feb 2016 9:14pm |
Cheers for the info pete.
26th Feb 2016 9:58pm |
