Home > Technical (L322) > Jump starting
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Jump starting
Ff refused to start this morning in heavy frost !!
Tried battery pack and jump starting, nothing, all I'm getting is clicking noise when I press start button.
Is it starter motor ?
Battery is less than year old
Post #419961 29th Dec 2016 11:36am
Maybe not enough power through the booster pack ?
Could be a completely dead battery - that would be the first check for me - take it into Halfords or Euro Car Parts or probably most other auto factors & they will test it for you
Or if you're a member of a recovery service, just call them Thumbs Up
Post #419966 29th Dec 2016 11:45am
Wogger
On to recovery firm now !!!
Thanks Sad
Post #419972 29th Dec 2016 11:59am
Andy B
Had the same issue a few weeks back. Suspect the battery is shot. The breakdown guy attached the booster pack for about 15/20 minutes before trying to start the engine and it fired up first time.
Good luck getting it going Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #419974 29th Dec 2016 12:11pm
Wogger
Cheers Surprised
Post #419976 29th Dec 2016 12:31pm
Wogger
Think it is the battery.
Does anyone have any experience of the Odessey batteries that are advertised in the Land Rover mags?
Will it be worth fitting one ?
Post #420028 29th Dec 2016 5:24pm
Andy B
Not experienced the one you mentioned. I got this from ATS :-
https://shop.atseuromaster.co.uk/car-produ...29/3464022
5 Year Warranty
LR wanted to charge (scuse pun!) me £260+ Rolling Eyes SDV8 AB MY 2019
Post #420029 29th Dec 2016 5:31pm
Wogger
Thanks for wise words chaps.
Just fitted fresh battery, and she fired up first go Shocked
I've noticed that both positive and negative clamps don't seem to tighten up as much as I'd like !!
And the battery isn't held that secure in its tray !!
I'm sure that over time this has an adverse effect on its performance ?
And who decided that you need to be a gynecholigist get a battery in that space Embarassed
This is the third battery I've had fitted in 12 months, so something is amiss Shocked
Post #420341 31st Dec 2016 1:55pm
The battery should fit well & be completely free of movement.
I've not heard of any issues with the clamps not being tight enough before.
There's a Wiki guide on how to change the battery - if you put the bonnet into access mode it makes life a lot easier Thumbs Up
They should last closer to 5 years - so it does indicate that you have some other issue somewhere - make sure you buy one with a warranty & keep the receipt. I had a 3 year old one fail (with 5 year warranty) and Euro Parts exchanged it without question.
Post #420348 31st Dec 2016 2:24pm
Wogger
Cheers Alistair
I'm off to my local auto electrical garage next week, see if they can help Thumbs Up
Post #420350 31st Dec 2016 2:30pm
RR2008HSE
Careful with a jump. If your battery is totally dead, you'll put a lot of strain on the alternator once it starts up. If the situation allows, charge up the battery first, or replace. Good luck.
Post #420828 2nd Jan 2017 9:29pm
Wogger
I've got a suspicion that the alternator is the problem
Post #420831 2nd Jan 2017 9:42pm
