Home > Technical (L322) > Jump starting |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7774 |
Maybe not enough power through the booster pack ?
29th Dec 2016 11:45am |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
On to recovery firm now !!!
29th Dec 2016 11:59am |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Had the same issue a few weeks back. Suspect the battery is shot. The breakdown guy attached the booster pack for about 15/20 minutes before trying to start the engine and it fired up first time.
29th Dec 2016 12:11pm |
Cheers |
29th Dec 2016 12:31pm |
Think it is the battery.
29th Dec 2016 5:24pm |
Not experienced the one you mentioned. I got this from ATS :-
29th Dec 2016 5:31pm |
Thanks for wise words chaps.
31st Dec 2016 1:55pm |
The battery should fit well & be completely free of movement.
31st Dec 2016 2:24pm |
Cheers Alistair
31st Dec 2016 2:30pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Careful with a jump. If your battery is totally dead, you'll put a lot of strain on the alternator once it starts up. If the situation allows, charge up the battery first, or replace. Good luck. |
2nd Jan 2017 9:29pm |
I've got a suspicion that the alternator is the problem |
2nd Jan 2017 9:42pm |
