Home > Technical (L322) > chain guide renewal - 2004 BMW 4.4L V8 Petrol - Update |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I used Febi Bilstein chains and guides in mine which seem ok but I have another underlying issue of potential head gasket failure and also a top end rattle which I think is because the engine was overheating after a top hose blew off so I don't think any of this is related to my chains and guides
7th Jan 2017 12:27am |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 354 |
I'm thinking you'd need to budget for about £1200 all in, though you might get it a little cheaper by finding the right place.
7th Jan 2017 5:22pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
Thanks Andy, was hoping you would pop up. Just waiting for saint v8 to give his verdict now!
7th Jan 2017 5:28pm |
Do not need to take out the engine, think only some of the BMW cars require this, most garages don't like to do the job.
7th Jan 2017 7:58pm |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
Thanks for the info HC 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie |
8th Jan 2017 12:44pm |
No problem, are you looking to change the guides for fun or have yours broken up ? |
8th Jan 2017 1:02pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I'm getting a price for mine this week so shall compare.. my engines relatively quite and I love the car so if it's going to prolong its life then I'm getting it done..I shall report back on Tuesday once mechanic looks over it..any other wee jobs I should add in as he will have it in bits and I reckon it's worthwhile doing.. |
8th Jan 2017 1:36pm |
Cool, i think my head gaskets are ok, i think i had a problem with bleeding the air out after fitting the 80 degree mod, never had a problem with the standard stat.
8th Jan 2017 8:38pm |
Well this is depressing.....
11th Jan 2017 6:56pm |
I am getting a little confused as to who has got what !!
11th Jan 2017 8:36pm |
Hi Andy,
11th Jan 2017 9:59pm |
Blimey, you have been around the houses
11th Jan 2017 10:45pm |
Hi Andy,
11th Jan 2017 11:22pm |
187 K and LPG you would be a good candidate for guides, the timing chain wont have failed, it may be a longer than when it was born but not enough to make a noise, the timing chain tensioner is one nut, but it is not in a great place to get to without the right socket and bar and not likely to have failed to the extent of causing, and i quote "A noise like a skeleton w@nking in a biscuit tin"
11th Jan 2017 11:50pm |
