Home > Technical (L322) > TD6 Intercooler Hose again :@ |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
It's still not right, I replaced the hose with a Bearmach one, convinced it was properly fitted but still seem to be having the covered in oil problem?
26th Feb 2017 3:33am |
26th Feb 2017 3:38am |
Thanks lounge on wheels
26th Feb 2017 10:01am |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
I have just ordered a set of four black silicone ones for £110 including T bolt clips and postage. Just the one hose I needed was about £35 for a pattern part and I dare say, as one has gone, the rest are probably on the way out. |
26th Feb 2017 10:46am |
Have you fitted them yet? I did have a look at them yesterday the only thing that worries me is the fitting into the intercooler as standard ones have a clip type fitting, in not sure if a silicone hose would stay on?
26th Feb 2017 11:08am |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Sorry to hear you still have probs,
26th Feb 2017 11:17am |
Still loss, groves are clear but it just won't go on any tighter! The seal has split and fallen out too
26th Feb 2017 1:32pm |
Looking at a picture of a genuine hose, the part that clips on to the intercooler is held on the hose with a jubilee clip, so I guess you just do the same with the silicone one.
26th Feb 2017 3:40pm |
I can see what you mean about the genuine hose, the bearmach one I have isn't like that! I was hoping that the silicone ones go straight onto the intercooler, losing the need for the clip mechanism! It seems long enough so I guess you could get a tight seal on it!
26th Feb 2017 3:53pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Is there possibly an 'o'ring missing?
26th Feb 2017 4:29pm |
I guess it's quite possible, trouble is pictures are very unclear on the internet, haven't found a close up of inside the pipe yet! |
26th Feb 2017 4:43pm |
Here you go....
26th Feb 2017 4:56pm |
I've only found 1, I don't remember seeing 2 when I got the hose.
26th Feb 2017 4:59pm |
It might be just one, and it's a trick of the light.... but what ever the number there will be at least 1!!!
26th Feb 2017 5:09pm |
