Home > General (L405) > Newbie looking to buy approved used l405 autobiography |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 654 |
They are great cars FFRR. My first one was a 2013 Autobiography and I thought it was lovely and I've had several since then but it's clear that they do get even better with each update. Things like sunroof's, trackers and improved tech all get added on the newer cars, which just make the ownership that bit better. For instance I regularly put large loads in the back and need to have a flat-ish floor but on later models (15 I think) when you lower the back seats the front one automatically move forward first to stop you snagging one seat on the other and when the back ones are down the front returns to normal. Then there access mode, which drops the car when you park to allow easy access to and from the car. There's lots and lots of these that get added or improved as the car develops along it's life cycle.
12th May 2017 9:51am |
If I were choosing my next car the engine wouldn't be the deciding factor. It would be the condition, mileage and spec of the car in a colour I like. If I had two identical cars, one with the 3.0 and the other with the 4.4 it would be tougher because they are both great units. Personally I think the tdv6 is better suited to the car for refinement alone but then I don't go razzing around and prefer to waft along. The tdv6 is is definitely more economical but not by a margin that knocks one out of contention and the 4.4 does make you smile when you open the taps and some may prefer the extra noise. |
12th May 2017 9:58am |
Mattl29 Member Since: 09 May 2017 Location: Derby Posts: 11 |
Great makes a lot of sense, my continued 1 hour daily slog on auto trader continues! Will def go the approved used route I think for the piece of mind and goodwill. I know you can get an inspection done (pardon the phrase!) and take out the LR warranty with dealership but don't want to risk it if the car failed in a big way on something and then then all ache of getting in rectified with the no approved dealer. One interesting thing I have found is that a few non LR approved dealers are advertising an extended LR approved warranty (beyond manufacturers standard), I wanted to double check this so called the LR Approved warranty plan who are Car Care Plan, the guy I spoke to was really friendly but explained that need to be careful as an non approved dealer is unable to transfer the extended warranty to purchaser and that the only way an extended warranty of theirs can be transferred is on a private purchase! Interesting and maybe useful to others so wanted to share. We went over this a couple of times to the point where he said that cars claiming this should not be advertised in this way as the warranty would not be valid for a claim, other warranties of course will vary but theirs which is the Land Rover approved is structured in this way. |
12th May 2017 11:05am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1344 |
Note that there have been quite a few instances of the 3.0 engine seizing. I asked my LR dealer about this and even in a smallish place in the Scottish Borders they had replaced "several". That said they had a 4.4 which had needed a new engine too, but that seemed a surprise and isolated incident. Only Range Rovers since 1988 |
12th May 2017 11:29am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
Hence even more important to have the LR warranty 2017 4.4 SDV8 Autobiography
12th May 2017 11:36am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7791 |
If you're restricting the search to Approved Used then why are you looking at Autotrader and not the official LR used website ? |
12th May 2017 2:19pm |
Prefer the layout on iPhone of auto trader and search function seems better. When you use LR website on desktop or mobile it has limited functionality that just doesn't work! E.g if you want to search for more than one colour sometimes it will not let you, it does not have all options to select and eliminate by, it has limited cars per screen. On auto trader you can just scroll through / save any car to your own garage / it shows approved used with a "tick" and I have been using for last few months and funnelling my wider search across manufactures down to a FFRR!. Maybe it is habitual but just prefer the system, I also have alerts set up based on several Pre defined criteria which show me the latest cars added that meet my search |
12th May 2017 3:10pm |
Makes sense |
12th May 2017 7:52pm |
Lutonboy Member Since: 26 Dec 2016 Location: Bedfordshire Posts: 35 |
I've driven VSE and AB (I own one) and for me the AB does have a little extra refinement in its use of extra leather. I have the leather headlining as well and that is awesome, definitely recommend looking at cars with both headlinings to compare, but for me it was an option well worth specifying (especially as it was zero cost).
16th May 2017 3:13pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1060 |
Aintree green as well very nice get some pictures up Lutonboy. |
16th May 2017 3:24pm |
caymanblack, I put a couple up on my post here: http://www.fullfatrr.com/forum/topic42767.html |
16th May 2017 3:48pm |
Wow its lovely , love the expresso as well. Thanks. |
16th May 2017 4:11pm |
Singh911 Member Since: 04 Jun 2017 Location: London Posts: 50 |
Hi - I am looking for a car at the moment and I missed out on the car I think you were talking about above - in Aruba at Milton Keynes iirc? I have a budget of early £60ks and have settled on SE spec with sliding roof and winged headrests (btw can these be retrofitted because this seems to rule out a large number of cars). I need a towbar although I am unsure whether to buy a car with one with it fitted for fear of it having had a hard life. There seem to be wide variations in pricing - and not just the odd £1-£2k but by £10k at times. Contrast the car you mentioned v many at similar money with a lot more miles on 14 or 64 plates for no obvious reason? Surely dealers must know that some cars are not priced competitively - but I wouldn't think to offer £7-£8k below the sticker price because I fear they wouldn't take me seriously. Maybe the September 17 mooted facelift will mean more cars coming onto the market and better value? Cheers |
12th Jun 2017 6:55pm |
Hi there and good choice on your spec. I've had AB's and VSE's and the SE is the sweet-spot of the range IMHO, although the AB is worth a bit extra. Given what you've mentioned you should be able to find what you are looking for but bear in mind that retro fitting the winged headrests is very, very expensive (thousands rather than hundreds and the tow bar too isn't cheap so look for cars with them in.
12th Jun 2017 8:08pm |
