Home > Technical (L322) > Speed sensor faults remains (HDC/ABS/Parking Brake etc) |
Keith A Member Since: 25 Oct 2012 Location: Sherborne, Dorset Posts: 105 |
So I still have the wheel speed sensor faults triggering the HDC/ABS etc issues.
22nd May 2017 11:36am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
abs unit contacts is a possibility , give them a good clean with a bit of emery paper and a squirt of contact cleaner and see how it goes , if you still have issues you will need to loop check with a meter from the connector block to the relevant wheel sensor connection , if no faults there its time for a new (2nd hand off ebay for about £100) abs module , make sure the numbers match up though |
22nd May 2017 2:12pm |
So just went to have a look at the wiring loom to the abs module, looks like a bunch of slightly melted/worn wires which have rubbed against the engine block. Could be the issue!
25th May 2017 5:07pm |
Cleaned up and the core of the green wire is exposed and so is the blue/green one albeit only slightly.
25th May 2017 5:22pm |
Hoping that as the wires were only just rubbed free of the sheath that a bit of electrical tape round each worn wire and the re-wrapping will do the trick.
25th May 2017 6:32pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
Good find! The green and blue/green are the 2 wires for the right rear ABS sensor so very likely that you've solved the problem. |
25th May 2017 9:22pm |
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 |
So did that cure your problems Keith, i checked my wire loom but all looks like new. Put in a new sensor just in case, still the same after standing for a couple of hours all warning lights dissapear then after driving 5 to 10 klms i get the bong and inactive suspension, havent had the grinding noise again, i have done the pump up with the kit and the pump seems to be working well, even when driving with the suspension inactive warning showing i can hear the pump run intermitantly. After the faults clear i can raise and lower the suspension several times with no problem the fault only occures when i am driving, all seems normal except i cannot raise or lower, any new ideas would be appreciated. |
29th May 2017 9:44am |
Only done 100 miles since finding it, however all seems to be fine.
29th May 2017 10:48am |
Hello again, well my problems are persisting, it can,t be major just enough to drive me up the wall. The symptoms seem to change but the resulting bong and suspension faults remain constant. The newest thing is i drive along no problems and all is quiet, then i stop and leave for a while, it doesn,t matter how long 5 min or 1 hour when i come back and switch on the ignition i get the bong and no suspension. Then when i stop and switch off the front drops slowly and then bounces back up. That grinding noise i experianced befor hasn,t happened again and thinking back it sounded more like a gear meshing grind so my previous assumption that it was abs related must have been completley wrong. What a gear meshing noise and inactive suspension have in common is another thing to torture my brain but i am hoping the combined brilliance of this forum can solve the riddle. Thanks if you can help. |
17th Jun 2017 12:12pm |
Guessing can be an expensive game. If you know anyone with an IIDTool bluetooth version for your model then it can read the fault codes.
17th Jun 2017 1:35pm |
Ok thanks will check the falt code tomorrow, i have the iid tool so will check. |
17th Jun 2017 1:51pm |
