Home > Technical (L322) > Air Conditioning Condensor TDV8 MY07 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
the td6 condenser is at the front so it gets loads of damage from stones etc, i gather yours must be in the same location..
4th Jun 2017 1:38pm |
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 157 |
Workshop manual just says move oil cooler and fuel cooler unbolt et voila, lacking in how do you actualy get in there to start with. Through the front / back ?? Took the grill off and all you see is fan and covers. No doubt grill off headlights and surrounds out, slam panel off would seam the obvious way in to me but some reading I have done says engine fan and cowl and take the radiator out first. If everything is under control you are not going fast enough.
4th Jun 2017 1:50pm |
Well as no one on here had any ideas, I went in blind and yes you can get at it all from the front of the car but you do have to take a lot of car off to get at it all. Not a problem fairly easy as long as it is taken step by step.
25th Jun 2017 8:44am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Well done. ______________________________
25th Jun 2017 9:48am |
unsolicited Member Since: 30 May 2016 Location: London Posts: 123 |
Looks much harder than the supercharged. I only needed to remove the slam panel and ease the condenser out! |
27th Jun 2017 3:39pm |
2006Rangie Member Since: 26 Jan 2017 Location: Toronto and Melbourne Florida Posts: 20 |
This looks like a phenomenal amount of work.
17th Sep 2018 9:13pm |
If it's anything like the 4.2 (it should be), the A/C condenser can be removed carefully upward without removing radiator or disturbing coolant hoses. You will need to remove the front slam panel (not difficult really). There should be some threads around describing the procedure.
18th Sep 2018 7:29pm |
25th Sep 2018 7:33am |
As I recall I think there was a dowel there, yes. I gave up at the bolt stage, the replacement pipe sections were not ruinously expensive - it was just easier.
25th Sep 2018 7:10pm |
Yes, I confirmed that there are dowels after I had posted the question. I wrestled with it again today and it is showing the tiniest signs of movement across the joint but it will still not come apart.
26th Sep 2018 3:29am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1273 |
just put your dessicant in the oven for a few hours to regenerate |
26th Sep 2018 7:42am |
Would love to do that, but the existing condenser (and the new one which is a Nissens) both have the access plug at the bottom of the condenser rather than the top where the manual shows access of the OE.
26th Sep 2018 1:10pm |
Strange, the receiver dryer was integral with the condenser unit on mine. |
26th Sep 2018 5:29pm |
It is integral. It is a vertical cylinder about 40mm diameter full height of the condenser on the opposite side from the high- pressure pipe connection block. The problem is that they put the insertion cap on the bottom of the condenser instead of on the top.
26th Sep 2018 7:00pm |
