Home > Technical (L322) > Help with suspension fault. |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I think that one can be ignored.. the car doesn’t have ebv. It’s due to the fact it’s bmw electrics apparently ..I queried this with gap a while back |
14th Oct 2017 6:21pm |
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 |
OK,thats one less, i also get 0x-30 air qual sensor, that i thought could be ignored.
15th Oct 2017 12:35am |
15th Oct 2017 12:38am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
This: 1/60 x- 52 air suspension active/inactive is the one that needs further investigation! .
15th Oct 2017 12:56am |
Thanks for the offer but i am a bit far from you what can i do using ths iid tool non blutooth. |
I just reread your post. I get error code1/60x-57, you say x-52 ? I will do a scan when i get home.0ps my error i did mean x-57 |
15th Oct 2017 1:06am |
Ok let me start again, the fault code that i am getting is
17th Oct 2017 2:01am |
Can someone please help.the code i get from my iid tool 1/60x-57 is regular but there are different codes when i read the iid tool when the suspension is locked or when the fault cleares itself during the night. I cannot clear the fault (suspension active /inactive ) with my iid tool but it cleares itself over night.
23rd Oct 2017 2:58am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2309 |
Your vehicle's codes are quite different to later models like mine so the codes are meaningless to me. However can-bus faults can affect lots of mostly unrelated modules so a fault on one can cause unrelated faults. It is possible that faults that cannot be cleared one day will clear themselves overnight when modules go into sleep mode. Have you tried locking then unlocking to see if the faults have cleared, allowing at least 30 seconds between locking and unlocking but perhaps a little more, maybe 2 minutes? Perhaps one module is tying-up the can-bus whilst it isn't sleeping.
23rd Oct 2017 6:11am |
Thank you for your imput, very confusing these faults,as i said the fault and inactive suspension can appear even if the car is not running. One thing i noticed was by chance i had my drivers window open and when i switched off the engine and the front sagged i heard air escaping somewhere in the front, then it stopped and the front bounced back up? I am a retired boilermaker so there is no way i can hear the pump running whilst i am driving. so i was wondering whether i could fit a led globe that lights up when the pump runs, then i can at least see if the pump is being overworked and getting too hot. Another indication is the brake light that is normaly amber when the suspension inactive is on turns red after a while and again not always but the brakes still operate as normal, i fitted new brake pads not long ago.
24th Oct 2017 5:29am |
Are you sure that the indicator light is a brake warning light and not a suspension warning light? The suspension warning light can be either colour and usually amber when the reservoir takes too long to get up to pressure but red when a target height can't be attained.
24th Oct 2017 6:33am |
Thanks, but can you drive around with the iid tool connected? As for the red light on the dash, its not the ABS but the one next to it that has an exclamation mark I did my pump with a kit i got from UK so i hope that is not the problem.
24th Oct 2017 7:59am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
Have you looked at the compressor? The relationship to engine heating up may be a red herring. I would suggest it may be related to the compressor overheating rather than engine temperature.
24th Oct 2017 8:32am |
You can drive with the tool connected but it might be revealing if the various suspension values were looked at just with the engine running.
24th Oct 2017 9:54am |
