Home > Maintenance & Mods (L322) > Red DPF Full Warning Again! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
this pic from the WM indicates there are 4 temperature sensors on the exhaust , hence my amateur deduction that its probably not the thermostat,
19th Oct 2017 11:37am |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
Don't know how you are getting on with this but I ran a thread on a very similar DPF problem.
25th Oct 2017 8:08pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
Hmm, I certainly agree that LR should have done a recall or subsidised the turbo drain mod, but am not sure about the absence of it leading to the DPF filling and having to be replaced. I have had an oil weep on the second turbo for maybe 13,000 miles now, when last checked it was not getting worse and it is just being monitored, not least as I have been told there is no help from LR for the mod. I have never had a DPF light or problem, but most of my driving is 'oot the road' and I'm over 2,500 rpm at some point on many journeys so oil does not build up in the turbo. Perhaps I have just been lucky, but I think many of the problems will be the use of diesels for short journeys with lots of stop-start, rather than the drain issue.
26th Oct 2017 3:27pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Drive it like you stole it they say...
26th Oct 2017 3:50pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3678 |
Mine was very smokey before. I got the mod done and I have never seen a DPF warning, but since I had it done I have never seen a hint of smoke.
26th Oct 2017 5:30pm |
Found this which, although from VW forum, goes some way to explain the thesholds between a yellow DPF warning, red DPF warning and "completely screwed" scenario:
2nd Nov 2017 2:30pm |
not as good as my link 'write up' Greg..
2nd Nov 2017 2:35pm |
No doubt Stan, yours rocks!
2nd Nov 2017 2:40pm |
i'm not sure that additives actually work Greg, i put some engine redex in my old 4.2 and it didnt seem to do anything.. ... - .- -.
2nd Nov 2017 2:51pm |
Stan,
2nd Nov 2017 3:34pm |
just phoned him Mike and he says it's dependant on the particular vehicle but generally just the dpf part can be separated from the exhaust ...sometimes the exhaust system might have to be dropped down to get the dpf off ...
2nd Nov 2017 3:43pm |
Stan you posted the exhaust diagram at the top of this page, I can't see any flanges on the DPF.
2nd Nov 2017 3:59pm |
I got to have a good long look underneath mine yesterday whilst it was up on a 4 post ramp and I can confirm 100% that the DPF and silencer box are in 1 complete piece made from stainless steel.
Would be good to know it, even at 8ft it could be cleaned if need be.
2nd Nov 2017 4:10pm |
