Home > Maintenance & Mods (L322) > Passed her MOT, but told steering is 'heavy'
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
My 2003 TD6 has sailed thorugh another MOT Smile although the tester guy who we always use commented on the steering being very heavy, the power steering is still working, but what could cause this?
My partner drives the TD6 98% of the time, and she probably wouldnt notice any difference in it at all Whistle
Can the steering get 'heavier' over time??
Post #461286 18th Dec 2017 6:38pm
could be the servotronic valve, do a search and see if the symptoms are the same. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #461290 18th Dec 2017 6:55pm
CS
When it happened to my 2004 car the power steering motor was failing and needed to be replaced. Only Range Rovers since 1988
Post #461291 18th Dec 2017 6:57pm
Dolphinboy
It’s 99% likely to be your bcu (body control unit) under the passenger seat. Search for bcu on here and see a lovely talk thru by our colleague in France. I just replaced mine and instantly had perfect weighted steering again. Under an hour to do.
Post #461294 18th Dec 2017 7:21pm
bebechoon
France
Most kind, Dolphinboy Thumbs Up
mrblond: it's here if it helps http://www.fullfatrr.com/forum/topic40009.html
 It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 5 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #461398 19th Dec 2017 12:15pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
You ever change the power steering fluid ?
Post #461460 19th Dec 2017 8:39pm
mrblonde
cheers all
Rambles, errrr now you mention it, no i havent Embarassed Ive had her 6 years, done about 20k miles in her in that time
Should that be my first port of call?
Post #461547 20th Dec 2017 6:00pm
Rambles
I changed my fluid a few months ago
Original fluid was still in
Steering was noticeably lighter afterwards
Not saying that this will cure your problem...but a relatively simple and cheap job to do...
Post #461607 21st Dec 2017 9:10am
mrblonde
Cheers guys, interesting post Dolphinboy as a while ago I had 3 drains from fuses, 1 was the usual FSR (replaced that), the other was from the headlight wipers (pulled the fuse), and the 3rd drain was from the BCU fuse (cant remember the number, but theres a long post on here about it I started)
She's going in for new brakes and fluid in the next couple of weeks, and to have power steering fluid replaced, so if that doesn't solve it I'll look a the BCU (and no doubt come back with lots of questions too)
Post #462900 1st Jan 2018 5:16pm
bebechoon
France
Have you seen the Ken_Curtis's £70 'BCU repair option' post:
http://www.fullfatrr.com/forum/topic45704.html?
Yes, I know he's down oop North and you're not but you never know ...
Previous:
Disco II
Post #462909 1st Jan 2018 6:37pm
Sharpy1980
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Mine had heavy steering with no funny noises from the pump etc so I replaced the servotronic valve on the pas rack and it was an instant 200% improvement and it’s been perfect since and that was at least 12 months ago, the part was about £100 for a genuine part from a specialist and I changed it myself in about an hour and 1 of the 2 bolts was seized, probably the best £100 I’ve spent on the FF Thumbs Up
Post #462925 1st Jan 2018 6:54pm
mrblonde
Just had a very quick read of bebechoon’s link to Ken_Curtis thread and my passenger side rear door doesn’t unlock either, the more I read the more it points towards the BCU
I’ve got an iCarSoft code reader, will plug it in this weekend and see what codes/faults come up
Cheers guys
Post #463219 4th Jan 2018 12:07am
Rose
Australia 2003 Range Rover HSE 4.4 V8 Adriatic Blue
My RR was heavy in the steering it went onto susp inactive again and I had the faults cleared. Now the steering is back to normal.
Post #463227 4th Jan 2018 4:26am
mrblonde
Had the power steering fluid changed (hadnt been done since I got her, *cough* several *cough* years ago) Embarassed but no improvement
Now got to decide if its BCU, or servotronic valve related
Post #464635 15th Jan 2018 11:40am
mrblonde
Sharpy1980, how hard is it to change please? Am guessing not too hard, but im not great with a set of spanners Sad
Post #464637 15th Jan 2018 11:42am
