Home > Maintenance & Mods (L322) > Safari Spot Lights - Any Photos? |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
BlackPerth, that looks like Cibie Super Oscars
9th Jan 2018 2:29pm |
DallasRob Member Since: 28 Dec 2017 Location: Dallas, Texas Posts: 10 |
Land Rover part number VUB001090 for the L322 lamp kit and you’d also need the correct brackets: VUU500330 for 06-09 models and VUU500030 for 03-05 models. |
9th Jan 2018 2:39pm |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 |
Trebaix car looks like a 2012 - can you use the 2009 bumper mounts on a 2012 bumper? 2017 Range Rover Vogue SE SDV8 (with e-diff)
10th Jan 2018 12:24pm |
Not sure about that. I’ve done a lot of research on the factory driving-lamp kits for the L322s and I’ve never run across brackets for the 2010-12 trucks. My hunch is that the 06-09 brackets wouldn’t work. They are very substantial and have a lot of structure beneath the bumper cover (which must come off to install them), so because of the redesign of the 10-12 front end, I bet they wouldn’t fit those later bumpers. Just my guess. A dealer might be able to confirm. |
10th Jan 2018 2:24pm |
That makes sense - assume Trebaix used different mounts 2017 Range Rover Vogue SE SDV8 (with e-diff)
11th Jan 2018 9:57am |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Pulling up an old post, but does anyone have a part number for the auxiliary lights switch that came in the kit referred to above?
12th Jul 2021 11:04am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1366 |
The 2006 brochure I have says "Lamp Switch Panel FBX500010 also required". Only Range Rovers since 1988 |
12th Jul 2021 9:17pm |
Thanks for looking - appreciate that.
13th Jul 2021 11:33am |
The switch is depicted in this kit, but I don't see the specific part number for it.
14th Jul 2021 12:52am |
