Home > Maintenance & Mods (L322) > Safari Spot Lights - Any Photos?
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
Cam-Tech-Craig wrote:
^ They are genuine accessory spot lights from JLR sir Thumbs Up
I would like to add these to my car - is there a part number?
cheers 2017 Range Rover Vogue SE SDV8 (with e-diff)
2012 Range Rover Vogue TDV8 Luxury (SOLD)
2010 Land Rover Discovery 4 3.0 TDV6 HSE Stornoway Grey (SOLD)
2006 Land Rover Discovery 3 SE 2.7TDV6 Black, G4 Challenge Copy (gone)
Post #463868 9th Jan 2018 4:28am
nino_nino
BlackPerth, that looks like Cibie Super Oscars
https://www.ebay.com/sch/i.html?_nkw=cibie...5504242322
Post #463911 9th Jan 2018 2:29pm
DallasRob
United States 2008 Range Rover HSE 4.4 V8 Tonga Green
Land Rover part number VUB001090 for the L322 lamp kit and you’d also need the correct brackets: VUU500330 for 06-09 models and VUU500030 for 03-05 models.
Post #463912 9th Jan 2018 2:39pm
BlackPerth
Trebaix car looks like a 2012 - can you use the 2009 bumper mounts on a 2012 bumper? 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #463983 10th Jan 2018 12:24pm
DallasRob
Not sure about that. I’ve done a lot of research on the factory driving-lamp kits for the L322s and I’ve never run across brackets for the 2010-12 trucks. My hunch is that the 06-09 brackets wouldn’t work. They are very substantial and have a lot of structure beneath the bumper cover (which must come off to install them), so because of the redesign of the 10-12 front end, I bet they wouldn’t fit those later bumpers. Just my guess. A dealer might be able to confirm.
Post #464001 10th Jan 2018 2:24pm
BlackPerth
That makes sense - assume Trebaix used different mounts 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #464126 11th Jan 2018 9:57am
bishbosh10
Pulling up an old post, but does anyone have a part number for the auxiliary lights switch that came in the kit referred to above?
I am starting to plan the wiring of lights on my roof rack and want a factory look switch if at all possible.
Thanks Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #600380 12th Jul 2021 11:04am
CS
The 2006 brochure I have says "Lamp Switch Panel FBX500010 also required". Only Range Rovers since 1988
Post #600425 12th Jul 2021 9:17pm
bishbosh10
Thanks for looking - appreciate that.
Sadly that part number seems to be the plastic surround for the lower part of the centre console, not the switch itself. Bish.
2005 110 TD5 CSW
Post #600461 13th Jul 2021 11:33am
DallasRob
The switch is depicted in this kit, but I don't see the specific part number for it.
https://www.bputah.com/RR44/rr44lamp.htm
Will keep digging!
Post #600574 14th Jul 2021 12:52am
