Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 332 |
12th Jan 2018 6:11pm |
That is absolutely correct, and from what I can see the go directly into the plates. As soon as my replacement arrives, I’m going to break it open. 😁 |
12th Jan 2018 7:53pm |
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 50 |
in regard to the heated/cooled seat control module, i see lots that look identical but have different part numbers, mine is
12th Jan 2018 8:47pm |
Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57 |
Millerj90i was hoping to hot wire mine into working with an external thermistor, and use the whole assembly to heat the air in my biltong drying box! But I was a little over enthusiastic with the tear down 2006 RR sport HSE
13th Jan 2018 6:04am |
Zeppfish - great idea, good biltong is hard to get around here! |
13th Jan 2018 10:50am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3654 |
This got me to thinking - again dangerous - a thermistor is just a heat sensitive resistor so if the value of the resistance was known for a given heat the thermistor could simply be replaced with a resistor in line for a fixed heat setting. Geoff |
13th Jan 2018 5:29pm |
Geoff
13th Jan 2018 6:06pm |
I think its time I got my order in, if only to stop comments regarding my more than ample arse that needs warming up on a regular basis Geoff |
13th Jan 2018 8:42pm |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 90 |
Has anyone tried swapping the peltior unit from the squab into the seat back to see if it resolves the non heating problem without spending £260 on a new back module (heater and fan unit )?. |
15th Jan 2018 6:03pm |
Unfortunately the pettier cell in the back has the thermistors in, and the squab has none as the back unit controls the pair! 2006 RR sport HSE
15th Jan 2018 6:12pm |
Are you sure as looking at my underseat one it has the same 4 wires (2 green , 1 blue and 1 yellow) going into it as the one in the seat back ? Surely as it's a separate unit it will need the same type of temp control to stop any overheating . |
15th Jan 2018 6:17pm |
I was only going from memory as mine happened early last year!
18th Jan 2018 10:39am |
Has anyone done this yet, did it work? Geoff |
21st Jan 2018 6:23pm |
Not yet. Weather has not been conducive to ripping the seat out. But it does make a whole lot of sense |
21st Jan 2018 6:57pm |
