Home > Maintenance & Mods (L322) > Jumpleads
Andy
Got some now! Thumbs Up 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #44437 4th Jan 2011 1:49am
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
where did u get them from in the end ? onto no6 Range Rover
Everyone needs a hobby
Post #44756 5th Jan 2011 9:11pm
I had cause to require jump leads the other week when my drivers side window was being replaced, we let the battery drain by accident.
Standard thin jump leads got too hot and couldn't carry the current either. The thicker the better.
Anyone bought on of those Boost starters from Machine Mart? Discovery 4 HSE
Post #46832 20th Jan 2011 11:18pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Mate had a similar thing, always flat when he needed it. It would have to be a real high spec boost starter to start a FFRR from flat. I prefer keeping a 12v battery on standby in the garage. Topped up regularly handy in power cuts to.... but then I am a bit of a survival freak Laughing ... just don't mention the guns in the cellar Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #46836 20th Jan 2011 11:57pm
Motoberg
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
I was going to point you in the direction of the set Ive just bought from Halfords, but they've been very naughty boys and havent paid the bill for web domain hosting Laughing
anyway, they were around £40 and good for 7l petrol or 4l diesel engines if I recall
Oh yes, I big thanks to the nice man with the FFRR from Perth who jumped our dead FFRR in the Gelnshee ski area car park last Sunday Thumbs Up
3 years with the D3 and no bother, a month with FFRR and flat battery...welcome to Range Rover ownership Rolling Eyes
Post #46846 21st Jan 2011 8:53am
SteveMFr
Site Sponsor
DeltaC wrote:
I investigated an incident a couple of years ago where a qualified mechanic had tried to start a big engine that had one faulty battery on its 24v system and after numerous attempt he realised the problem and jumped the faulty battery with a good one. Electrically, it was an okay thing to do but a spark ignited the expelled hydrogen gas from the exhausted battery which blew the top off the battery and sprayed hot acid everywhere...
Have to ask here (and I'm not condoning skinny jumper leads): how does this incident relate to under dimensioned jumper cables?
And, just out of curiosity, what do you do professionally to investigate accidents like this?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #46848 21st Jan 2011 9:15am
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Steve,
Direct relationship to skinny leads = none. All I wanted to do was highlight that although it is seen as a straightforward operation, there are risks.
If you are placing high loads / stresses on components, they are more likely to fail - If for example:
The leads get so hot that the insuation fails and shorts on the body, it sparks...
If the battery is totally dead or faulty and therefore potentially going to release excessive Hydrogen...
Attempting to start with a sub-optimal battery also shortens the life of the starter motor and jumping has the potential to damage the alternator on either the jumped or the jumper.
Steve - Would you like to expand on your reason for the query? (ie Do you feel it is irrelevant or mis-leading or a.n.other?)
Post #46865 21st Jan 2011 11:56am
SteveMFr
Site Sponsor
No. Not at all Laughing
As I wrote, I was just curious about your investigation. And I did not see the correlation between the gas exploding and the thin wires - but that's it. I also wrote that I'm not condoning cheap jumper cables - I agree with you.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #46889 21st Jan 2011 2:45pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
DeltaC wrote:
Steve,
Was a little dramatic though, no ones talking bell wire here, think you really got to be taking the p*ss with wire diameter for the insulation to totally melt off.
its more important to connect in the order and use points away from the dead battery. 2004 black Vogue TD6
Post #46961 21st Jan 2011 11:20pm
DeltaC
Excellent. You've obviously got a bunch more experience than I, I bow to your greater knowledge 
Post #46970 22nd Jan 2011 12:21am
letsavit2
Come on delta dont be like that.
Your a safe nice and chunky expensive leads man.
Im a risk my life cheap ebay leads man.
So be it... Wink
To be honest mate not sure i know the correct order, i do live then make sure i do dead battery earth last well away from the battery....is that correct? 2004 black Vogue TD6
Post #46972 22nd Jan 2011 1:06am
SteveMFr
Site Sponsor
Ground (earth) away from the dead battery if possible, if not then def attach the dead battery first as it will likely be gassing considerably more than the good battery and you'll want to avoid sparks around it.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #46980 22nd Jan 2011 1:23pm
