Home > Maintenance & Mods (L322) > Jumpleads |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
Got some now! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
4th Jan 2011 1:49am |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
where did u get them from in the end ? onto no6 Range Rover
5th Jan 2011 9:11pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6350 |
I had cause to require jump leads the other week when my drivers side window was being replaced, we let the battery drain by accident.
20th Jan 2011 11:18pm |
Motoberg Member Since: 30 Nov 2010 Location: Aberdeen Posts: 4 |
I was going to point you in the direction of the set Ive just bought from Halfords, but they've been very naughty boys and havent paid the bill for web domain hosting
21st Jan 2011 8:53am |
Have to ask here (and I'm not condoning skinny jumper leads): how does this incident relate to under dimensioned jumper cables? And, just out of curiosity, what do you do professionally to investigate accidents like this? RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
21st Jan 2011 9:15am |
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 |
Steve,
21st Jan 2011 11:56am |
No. Not at all As I wrote, I was just curious about your investigation. And I did not see the correlation between the gas exploding and the thin wires - but that's it. I also wrote that I'm not condoning cheap jumper cables - I agree with you. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
21st Jan 2011 2:45pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
Was a little dramatic though, no ones talking bell wire here, think you really got to be taking the p*ss with wire diameter for the insulation to totally melt off. its more important to connect in the order and use points away from the dead battery. 2004 black Vogue TD6 |
21st Jan 2011 11:20pm |
Excellent. You've obviously got a bunch more experience than I, I bow to your greater knowledge |
22nd Jan 2011 12:21am |
Come on delta dont be like that. Your a safe nice and chunky expensive leads man. Im a risk my life cheap ebay leads man. So be it... To be honest mate not sure i know the correct order, i do live then make sure i do dead battery earth last well away from the battery....is that correct? 2004 black Vogue TD6 |
22nd Jan 2011 1:06am |
Ground (earth) away from the dead battery if possible, if not then def attach the dead battery first as it will likely be gassing considerably more than the good battery and you'll want to avoid sparks around it.
22nd Jan 2011 1:23pm |
