Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Kinger Member Since: 16 Feb 2018 Location: Somerset Posts: 11 |
Sun was shining today as the postie arrived with my Viton O rings, so i thought i may as well do the job right away.
7th Mar 2018 2:33pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
good job Mike and a great tip ... - .- -.
7th Mar 2018 2:38pm |
Once the pipe is out you can lift it into an easy access position, maybe theres about 4or 5 inches of play...
7th Mar 2018 3:27pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3674 |
Viton is supposed to have been designed to work at much higher temperatures, so hopefully the replacements will last much longer before they become hard brittle.
7th Mar 2018 4:00pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Cheers Kinger. Do you clean up the bell housing? Im thinking brake cleaner might do the job. I get a horrible smell of hot oil through the air vents at the moment, unless I hit the air recirculation button. 2011 RR Autobiography 4.4 TDV8 |
7th Mar 2018 5:22pm |
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 |
I didn’t clean anything other than the oil cooler assembly when I was doing the gaskets. It tend to collect more in the vee of the engine, so it’s taken about 3 weeks of burning the oil off and going up some steep hills to get rid of it. Or you could try sucking it out the vee while it’s apart if you have an oil sucker? Chris |
7th Mar 2018 6:58pm |
Certainly have, and a big metal sealy syringe which is quite handy for little jobs like that. 2011 RR Autobiography 4.4 TDV8 |
7th Mar 2018 7:16pm |
Think I’m going to go for a chassis wash. Still smoking and stinking. Cleaned it up best I could when it was apart. I just hope it’s not still leaking. 2011 RR Autobiography 4.4 TDV8 |
22nd Mar 2018 8:44am |
an update on my 'leak'...
22nd Mar 2018 8:55am |
22nd Mar 2018 9:26am |
i was surprised they agreed to do it all Mike, and with the starter motor replacement as well i have been told its around a £1500 cost.. ... - .- -.
22nd Mar 2018 9:30am |
Any idea why they change the oil feed pipe as well? Is it because the o rings don’t come separately or do they think there’s a leak on the pipe? Chris |
22nd Mar 2018 8:11pm |
the oil pipe can leak as well as the oil cooler...its easier for the dealer to replace the oil pipe than mess about with 'O' rings... ... - .- -.
22nd Mar 2018 8:34pm |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Happy days, Stan What do I put here then? |
22nd Mar 2018 8:40pm |
