Home > In Car Electronics (L322) > IID Tool newbie - I'm hooked |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Did someone say that a CCF edit puts all your audio settings back to default?
9th Mar 2018 5:11pm |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 |
Thanks GAC23; that might explain this conversation the other day, whilst on a long drive:
10th Mar 2018 10:51am |
What do I put here then? |
10th Mar 2018 11:27am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
^^brilliant
10th Mar 2018 11:40am |
Just tried it twice. Battery held out but CCF seems screwed. E.g. Mirrors no longer dip in reverse. Setting in dash set to on. Also tried locking then unlocking but no good.
10th Mar 2018 2:22pm |
Unless I’m mad - always possible - the first time you plugged your IID in, it will have made a CCF backup.
10th Mar 2018 4:16pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Greg, when playing with IIDTool I always connect Cteck charger (set to supply) to avoid low battery problem.
10th Mar 2018 4:18pm |
Third time lucky - Worked!!
10th Mar 2018 4:20pm |
Thanks Nino, I'll get a Ctek
10th Mar 2018 4:23pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3683 |
Greg/ Nino,
10th Mar 2018 4:47pm |
Glad you’re sorted.
10th Mar 2018 5:14pm |
Mike, what cteck you have, mine is 7A and it is sufficient and my battery is original factory so is going on 6.5 years old.
10th Mar 2018 7:43pm |
Nino,
11th Mar 2018 9:57am |
Greg/ Nino,
12th Mar 2018 12:42pm |
