Home > In Car Electronics (L322) > IID Tool newbie - I'm hooked
Page 3 of 4 <1234>
counter of beans
England 2012 Range Rover Vogue TDV8 Santorini Black
I must admit, when it switches your engine off for you, the bit where it says "update failed" or something, and the error messages that come up are all very worrying! But, as noted already, it's all fine when you switch it off then on again (classic IT fix!).
Gonna Go Double, have you done the suspension calibration yet? That's a piece of cake with the latest firmware, which you'll have.
Did someone say that a CCF edit puts all your audio settings back to default? I haven't checked mine since I last changed the CCF.
Post #471804 9th Mar 2018 4:09pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
I said it Smile
It puts your bass and treble back to the middle ... subwoofer to lowest ... logic 7 on.
I can't stand the sound with Logic 7 on - was how I noticed the changed settings the first time. What do I put here then?
Post #471811 9th Mar 2018 5:11pm
counter of beans
Thanks GAC23; that might explain this conversation the other day, whilst on a long drive:
Me - listen to this track, it sounds amazing on this system.
Wife - yeah it's OK but nothing special.
Me - cloth ears!
But actually I was thinking "she's right - for once....."
I agree that the sound is miles better with Logic 7 OFF.
Post #471913 10th Mar 2018 10:51am
GAC23
Rolling with laughter Thumbs Up What do I put here then?
Post #471922 10th Mar 2018 11:27am
GGDR
^^brilliant
Got in and drive home last night - no changes registered from the ccf - so I do think it was an actual fail.
And still no cruise control but I'll have another go with the engine running later today. I still think, since the IID turns the ignition off and on a few times I'll struggle with my battery though...
Thanks for the pointers guys.
Greg Cheers, Greg
Post #471924 10th Mar 2018 11:40am
GGDR
Just tried it twice. Battery held out but CCF seems screwed. E.g. Mirrors no longer dip in reverse. Setting in dash set to on. Also tried locking then unlocking but no good.
. Cheers, Greg
Post #471953 10th Mar 2018 2:22pm
GAC23
Unless I’m mad - always possible - the first time you plugged your IID in, it will have made a CCF backup.
I’d be tempted to restore it. Then make all your changes again. What do I put here then?
Post #471973 10th Mar 2018 4:16pm
nino_nino
Greg, when playing with IIDTool I always connect Cteck charger (set to supply) to avoid low battery problem.
.Nino
Post #471975 10th Mar 2018 4:18pm
GGDR
Third time lucky - Worked!!
I've now got:
- Blip sound on lock and unlock
- DRL's
- Numeric speedo in speedo
- one press super lock
And other stuff back online: mirrors are dipping on reverse again, cruise control is back and forward alert has come back online.
Must have been a glitch in the matrix.
Thanks team! Cheers, Greg
Post #471976 10th Mar 2018 4:20pm
GGDR
Thanks Nino, I'll get a Ctek
GAC yes I did a restore but it didn't seem to work.
All good now!
. Cheers, Greg
Post #471977 10th Mar 2018 4:23pm
Baltic Blue
Greg/ Nino,
I connect my Ctek to the car via the towing socket using one of Martin’s adapters and have tried using the iid without the engine running whilst “playing “, but it didn’t work for some reason. I got the low battery start engine warning after a few minutes?
I will try it again tomorrow if you wish?
Post #471981 10th Mar 2018 4:47pm
GAC23
Glad you’re sorted. Smile
Super lock is one setting I keep forgetting to try. What do I put here then?
Post #471988 10th Mar 2018 5:14pm
nino_nino
Mike, what cteck you have, mine is 7A and it is sufficient and my battery is original factory so is going on 6.5 years old. Very Happy
Post #472024 10th Mar 2018 7:43pm
Baltic Blue
Nino,
Mine is a Ctek 5, and I am also on the original battery.
I left it trickle charging for 4 weeks last month whilst I was on holiday and it started on the button no problem when I returned.
I am busy today, but will have another play with the iid and Ctek tomorrow. (The beauty of being retired, their is always tomorrow 👍👍)
Post #472086 11th Mar 2018 9:57am
Baltic Blue
Greg/ Nino,
It is raining today so I have just been playing with my iid in various ways to confirm the following;
Sitting in car with engine running iid shows 14.7. Volts.
Stop engine and it pretty soon drops to 12.2 Volts
Connect Ctek it reads 13.7Volts at socket, but still 12.2Volts on iid.
Disconnect Ctek re- start engine back to 14.7v
Confused??
iid is obviously not seeing charger?
Mike.
Post #472254 12th Mar 2018 12:42pm
Page 3 of 4 <1234>
