Home > In Car Electronics (L322) > IID Tool newbie - I'm hooked |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3685 |
Nino,
12th Mar 2018 1:13pm |
I have just re-tried, but switching ignition on or off does not affect iid voltage reading .
12th Mar 2018 2:43pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
Mike . i'm pretty sure these are the reason for your readings,
12th Mar 2018 3:07pm |
Thanks Stan, that makes sense, but Nino says he connects his Ctek when using iid?
12th Mar 2018 3:16pm |
i always run the engine, it's a diesel so it don't cost much.. ... - .- -.
12th Mar 2018 3:20pm |
Thanks for your reply Nino.
12th Mar 2018 4:10pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 326 |
The car can’t be running when flashing ECU. So battery needs to be good or use inline charger or jump leads and a running car works 4.4 AdBlu Tractor
12th Mar 2018 10:52pm |
certainly true for an ecu flash , but for ccf and height adjusts then run the engine.. ... - .- -.
13th Mar 2018 8:35am |
