Home > Maintenance & Mods (L322) > Facelift 2004 weird alarm buzzer!
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
So, as the subject suggests I recently acquired a 2004 petrol with a 2010+ facelift, It has an annoying high pitched alarm that goes off, not related to anything as far as I can tell. It is inside the cabin and low decibel but annoying. Tried turning things on and off, sometimes it will disappear for a couple of days then back again, long shot but any ideas guys ....... thanks in advance Bow down
Post #482430 2nd Jul 2018 4:46pm
any alarm type items in the cubby holes? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #482433 2nd Jul 2018 4:52pm
Rosco
Now Stan, that's interesting as the noise is not in the engine bay but somewhere in the cabin, however I am danged if I can find the source, any ideas? Bow down
Post #482436 2nd Jul 2018 5:34pm
maybe an o!d digital watch under the seat ??????? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #482438 2nd Jul 2018 7:05pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
My 2004 occasionally does it - normally when its hot outside and it sounds like its coming from under the drivers side. I've never got to the bottom of it but had a couple of theories that it was either a bug splettered on one of the parking sensors confusing it all (not likely) or the ECU cooling fan in the electrics box under the bonnet in front of the driver. Took that out and cleaned it and lubricated it.
It still comes on every now and again - lasts about 20 - 30 seconds, even when driving, but never got to the bottom of it. There is a buzzer box under the panel above the drivers seat - fairly sure that's what makes the noise, but why it happens and why its a different pitch to a normal noise coming from that buzzer I have no idea.
sorry, doesn't really help, other than tell me I'm not going mad. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #482439 2nd Jul 2018 7:18pm
Northern lad
have you by chance jet washed it? I gave mine two goes because she was seriously neglected. afterward it went mental every time she was put in reverse, (no there was nothing near the rear sensors) it does now seem to be settling down. turning her off momentarily does stop it though, perhaps ive inadvertently jammed something in one of the sensors.
just a thought!
Steve 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #482461 3rd Jul 2018 5:16am
Rosco
Interesting Nick, has got worse in this warm weather, its definitely linked to something as can start and stop when boot is opened or bonnet or door. Then starts randomly but I like the hot weather link, will keep looking , thanks Thumbs Up
Post #482465 3rd Jul 2018 6:51am
Rosco
just a thought!
Steve
Thanks for that Steve, I have only had it a month so not due a wash for at least a year Rolling with laughter
Seriously it hasn't been jet washed and all parking sensors are working OK, cheers Thumbs Up
Post #482466 3rd Jul 2018 6:58am
another guess is that it could be a faulty bonnet switch and a faulty alarm module.....does the alarm sound ok ie full volume and not a high pitch noise....
you can test by opening the window and locking the FF....wait a minute or so then put your hand in through the window to set of the alarm. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #482467 3rd Jul 2018 7:15am
Rosco
Stan, I like your thinking, will try that today it does start when boot is opened as well, but randomly, my guess is something to do with facelift wiring, its a weird noise the source is definitely somewhere behind the lower dash. More annoying than anything else.
My main concern as a long time paranoid 322 owner is the bloody battery Rolling with laughter
Post #482468 3rd Jul 2018 7:20am
the battery would certainly be a concern if this is happening all the time...
the only thing i can think of which is in the lower dash (by drivers footwell) is the front pdc buzzer... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #482470 3rd Jul 2018 7:39am
I had such a noise for a short period of time, I had a suspicion it was caused by something in the large under bonnet electrics box with the noise coming into the cabin via small air duct from the box ventilation fan. Before I got round to having a detailed look the sound went away and has not returned for some years now.
Post #482472 3rd Jul 2018 7:54am
another thought is that the conversion might have chaffed or caught a wire that feeds the pdc and when you go over a bump or such it sets of the sounder. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #482476 3rd Jul 2018 8:48am
nicksaab
I would lower the panel above the pedals and expose the PDC sounder box - see if its that making the noise - or maybe disconnect it for a while and see if it still happens. Or press the PDC button when it goes off to see if that stops it.
As I said above mine only ever happened occasionally when warm - I think I have convinced myself its bug splatter on the one of the front bumper parking sensors - if it is, then that box holds the key.
But probably not a bad idea to clean and lube the cooling fan in the ECU box anyway. Current Fleet:-
Post #482487 3rd Jul 2018 12:54pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
long shot for you, but I had a strange noise in the cabin, front area.
It would only sound some of the time, any how it turned out to be a faulty PDC and the speaker was making the sound as if parked up to something close....but not the beep, beep close proximity sound you normally have.
PDC changed and no strange sounds when on the move.
Check all the PDC that they are having that positive clicking sound when RR is on. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #483803 19th Jul 2018 3:45pm
