Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
Graeme,
1st Aug 2018 8:19am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Cheers Mike, yes I'm on that one, just wondering if Graeme was using a different one.
1st Aug 2018 8:21am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2307 |
Mine is a copy of the CD issued at the time which also has the part numbers rather than just a diagram reference. |
1st Aug 2018 9:01am |
Graeme it's Bank 2 - Sensor 1 I was also told it's near the manifold RHS of the engine (when standing in front) Will have another look at the Microcat diagrams. Might be the one you called out as LR022893. Cheers, Greg Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
1st Aug 2018 9:36am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Mike, nice job with Microcat
1st Aug 2018 10:18am |
This one (highlighted in yellow) looks like it's going into the manifold. It's marked as Exhaust Gas Temperature
1st Aug 2018 6:41pm |
Greg,
1st Aug 2018 9:06pm |
looks about the same from the underneath Mike
1st Aug 2018 9:24pm |
according to the workshop manual, there's a couple of exhaust manifolds in there somewhere...
1st Aug 2018 9:33pm |
Greg,
2nd Aug 2018 7:59am |
Thanks Mike, well I did browse through his photos.
This location is clearly not the EGR sensor (which is on top of the intake system, see Page 1 of this thread) - and explains why some people have have their EGR sensor replaced and the fault return, e.g.:
I think this has led dealers to wrongly write off this, having replaced the EGR sensor, as a ghost code. It may be all linked to the EGR system as Craig suggests but my personal theory it it's a typo. The EGT (Exhaust Gas Temperature) sensor in the manifold is this one: Part: LR052169 (previously LR022893) Sensor - Exhaust Gas - Temperature and it seems you need this tool too: JLR-303-1573 Remover, Exhaust Manifold Temperature Sensor The workshop manual even has a chapter explaining the replacement procedure called exhaust manifold temperature sensor.pdf (not sure if I can upload a PDF?) My EGT readings confirm the whole theory. They show this one as constantly on 100 degrees:
Further confirmation is the stinky smell when idling cold and also my DPF is filling up. Both of these Craig has mentioned as symptoms. Ok brass tacks - access doesn't look easy (see Mike's pic a few posts up) BUT actually I've had a really good nose in the engine bay today and I can actually see the sensor. Just. It's near the battery and straight down. To get to it I'll need to remove the cabin filter plenum box and the battery surround and a few other bits. That's the detective work so far. This weekend, as GraemeS suggested, I'll remove the plenum and some other bits so I can unplug the sensor to check that is in fact the dud one reading 100degrees. And I'll order a the tool and a sensor . Stay tuned, hopefully I'll be able to tackle this the following weekend when I've got the part. . . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 10th Aug 2018 7:14pm. Edited 1 time in total |
10th Aug 2018 6:06pm |
@GraemeS - be good to know your thoughts - In the same thread as Craig's comment, I read that you had the same error code in 2016 and changed your EGR sensor. Be good to know if that did - or didn't clear the P040D(2F) .. You also correctly called the sensor part number ^^^.
10th Aug 2018 7:13pm |
Mine's EGR temp sensor fault indeed returned very soon after the EGR temp sensor was replaced.
10th Aug 2018 9:39pm |
ok interesting. So do you show the P040D-00(2F) fault now?
10th Aug 2018 9:49pm |
