Home > Technical (L322) > oil pressure indicator flickers but oil level is max ? |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
My 2004 4.4 doesn’t use any oil so yours is going somewhere. That’s is a lot to lose so have you checked your cam covers and also check that your dipstick has a slight vacuum using a bit of cling film or latex glove for an indication of PCV system health.
16th Aug 2018 11:23pm |
gillech Member Since: 03 Nov 2015 Location: montreux Posts: 18 |
thank you,
17th Aug 2018 2:25pm |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
That sounds like a faulty switch or pump you need it sorted asap engines cost a lot more than switches or pumps |
17th Aug 2018 7:16pm |
Those temperatures are fine, mine was getting up to 115 deg c due to bad bleeding. i bought an adapter and pressure gauge that plugs into the oil pressure sender on the oil filter housing. |
17th Aug 2018 8:49pm |
Rovah Member Since: 12 Apr 2018 Location: MO Posts: 5 |
Any updates on how you fixed the issue? |
5th Oct 2018 3:05am |
Me or the OP ? |
5th Oct 2018 4:44pm |
Sorry. My question was for the OP. However please feel free to let us know how yours was resolved. Was it a faulty sensor? Thanks |
5th Oct 2018 10:38pm |
No, mine was as above, it was overheating slightly due to bad bleeding. I have also fitted the 80 degree stat mod. now, My temp was going over 110 degrees. C
5th Oct 2018 11:35pm |
Curious...The instrument cluster temp gauge didnt show the slight overheat due to bad bleeding? |
6th Oct 2018 1:04am |
