Home > Technical (L322) > Need a 4.4 TDV8 FBH guru
Page 1 of 3 123>
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi folks,
Trying to get my FBH working and getting nowhere fast!
Firstly where the bloomin heck is it?
Found the fob module and antenna, don't think they are pairing properly.
Secondly, tried my IID to test it, so turn off AC on the car, run the prep routine, all good, run the prime routine E7 fail, run the heat routine E7 fail.
Where am I going wrong?
Cheers
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #491764 10th Oct 2018 7:33pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Have you made sure its full , i fill mine every other week !!!!!
Only joking , its behind the passenger side front wheel , im no expert but i believe it has to be a certain temp for it to work.
Hopefully someone much more helpful will be posting soon. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #491765 10th Oct 2018 7:46pm
Bushy30
Thanks Dolph, in the wheel arch? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491770 10th Oct 2018 7:57pm
dolph34
Yes sir, on a cold day it can scare the hell out of you when you see smoke coming out the side of the car. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #491771 10th Oct 2018 7:58pm
Bushy30
Well that would explain why I can't find it then.
I wonder if the numpty body repairers who had it a couple of weeks ago to replace that wing disconnected it and not reconnected it then?
Already found my electric fan disconnected Sad Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491773 10th Oct 2018 8:01pm
mpirie
As Dolph says, it's behind the nearside wheel arch, under the battery.
If my memory serves, it will come on automatically when the outside temp drops to around 5 to 8 degrees C.
There is a routine to pair the remote with the receiver, in fact, there's another active thread ongoing for FBH. Search the forum.
Mike
Post #491775 10th Oct 2018 8:04pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Remove batteries from remote for 30s. Replace batteries. Pull fuse 16 in the boot. Hold off down on the remote. Push fuse in while continuing to hold off on the renotr. Wait for remote to flash. Job done. Did it last nihht on mine Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #491780 10th Oct 2018 8:08pm
dolph34
Not connecting the fan is unbelievable, a friend of mine with a 2 year old merc had a similar problem when a merc main dealer forgot to reconnect the fan , my friend has no mechanical knowledge or common sense and kept driving it on a hot day a blew the head gasket, i had a quick look and the fan connector was lying loose !!! It might be worth a check to see if its all connected up as it should be. Did you try running it from the display screen ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #491782 10th Oct 2018 8:10pm
Bushy30
No, only tried running it from my IID tool
Thanks DMRR, tried pulling the power from the unit and keeping the off button pressed this evening, red led flickers for 5 secs and then stops, doesn't sound right to me Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491787 10th Oct 2018 8:29pm
DMRR
Well that means it's paired. There must be another issue if its now not firing. Does the vertical orange light come on in the cabin when you press on - I fact does the light on the fob go from Amber to green? " Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #491791 10th Oct 2018 8:45pm
Bushy30
No, pressing the on button on the fob just results in red flashing LED
Never looked for a light in the cab!
Where's the light in the cab? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491795 10th Oct 2018 8:53pm
DMRR
I'm on my mobile so can't see what version of the l322 you have. If it's pre 09 then it's above the 'on' switch for audio etc.
Best bet is to try timed climate - set it for 5 minutes in the future and see what happens while you are sat in it.... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #491797 10th Oct 2018 9:00pm
Bushy30
It's a 2011, will give it a go tomorrow morning Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491802 10th Oct 2018 9:11pm
kooky_guy
I would have thought the remote is irrelevant. It should operate from the IID Tool. I assumed this would be independent of outside temperature since it is for diagnostic purposes.
I need to have a look at mine soon as that stopped operating last winter - I assumed it was the battery voltage but it still doesn't seem to be working even with a new battery.
My brother suggested I try the Purge function on the IID Tool as that cleared his FBH out on his D4. I think this should operate regardless of the temperature. It produces lots of smoke though, apparently. 2010 4.4 TDV8 Vogue SE
Post #491832 11th Oct 2018 7:57am
Bushy30
As far as I can understand IID does operate regardless of temperature.
Sat in the car, having tried timed function, all seems to kick in, blowers on, air duct paddles move, big whiring noise from under front near side wing, so at least something is working, neither the remote nor IID got that far.
Problem is I'm not sure there's any heat, and I don't have time for further investigation today, oh and the whiring stop for 2 seconds, carried on then stopped again Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491838 11th Oct 2018 8:35am
Page 1 of 3 123>
