Home > Maintenance & Mods (L322) > dynamic indicators |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
a while back i posted this thread re dynamic/sequential indicators on the audis and how i liked them...
12th Nov 2018 12:52pm |
hence my ref to 2010-2012 led indicators.....
12th Nov 2018 2:11pm |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 |
My bad......I thought all 322 had the single DI lamp, I guess if the LED pcb assembly can be physically rewired you might be able to sequence some how, but it’s only going to be limited to within the small round DI reflector, not sure it’ll be very visible as a sequential system as in the long thin type that Audi/BMW have. David
12th Nov 2018 2:16pm |
if you fast forward to 6.12 on this video you will see the 2010-2012 indicators in action...
12th Nov 2018 2:25pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Stan, i think they are being worked on at present by Powerfuluk LTD...
12th Nov 2018 2:53pm |
thank you craig...i wait in much anticipation... |
12th Nov 2018 3:03pm |
i dont suppose you have any more info on this Craig? |
1st Dec 2018 2:29pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Was looking at those too - Stan I picked up a 2011 tail light with a broken lens from another member.
1st Dec 2018 4:39pm |
i thought this would tickle your fancy greg
1st Dec 2018 5:32pm |
I'll get it out, pull out the track and post a pic....
1st Dec 2018 5:42pm |
nice one greg..
1st Dec 2018 5:50pm |
No more info I'm afraid Stan as i haven't been there for weeks and weeks! Alas been too busy!
1st Dec 2018 6:40pm |
Close up of the ribbon cable:
1st Dec 2018 8:07pm |
When i made my last set of lights for my 322 i had to get two damaged lights and use the back of them then take two perfectly good lights and cut the back off slowly slowly slowly!!! Until i was left with four halves which i PU glued back together after assembling... |
1st Dec 2018 8:35pm |
