Home > Maintenance & Mods (L322) > 2010 - > deployable steps fitting. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 697 |
It’s not as bad as I’m making it sound, I can’t remember the details but following the excellent write up on here I found it very straightforward |
23rd Feb 2019 2:24pm |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 125 |
Looking for tips guys please.
28th Apr 2019 8:54pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
You can fit the brackets without the step treads on
28th Apr 2019 9:48pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 527 |
Indeed I fitted mine with them retracted and with the steps still in place. The awkwardness was on the drivers side, but because of the cylinder in the way of getting a spanner on the bolt heads not the steps themselves.
28th Apr 2019 10:56pm |
Yes I shall endeavour to fit without deploying - don't really have much choice atm.
29th Apr 2019 8:58am |
It would seem most likely that they are switched off indeed! Current: 2011 FFRR Vogue SE 4.4 TDV8
29th Apr 2019 9:23am |
When my old steps weren't working, they gave every sign of being "dead" rather than just switched off as the light on the switch didn't flash when doing the on or off routine. For some reason (and before I swapped to the new steps) the switch suddenly did work and do its two or three flashes as it says it will in the book - but this was after a dozen or more attempts over several days. I've no idea what changed, but they work now and I can switch on or off at will. If your telltale flashes its a different problem, but if not, keep trying! Mike - MPx
29th Apr 2019 9:39am |
As for you; no led indications to say anything is happening...
29th Apr 2019 10:14am |
Okay so they are now fitted and working perfectly. They were 'switched off'. Following the manual (RTFM) I was able to switch them on first attempt
30th Apr 2019 12:03am |
30th Apr 2019 9:03am |
Well done! I'm guessing you no longer want my old steps? I did measure up the parcel eventually - 180x50x30 at its widest points and something over 31kg weight. Mike - MPx
30th Apr 2019 5:50pm |
Yeah after I looked up the price of the harness and control module, it was only a wee bit dearer just to get a brand new set so just went for it. £390 delivered for a genuine set
30th Apr 2019 6:40pm |
Jamessmith Member Since: 14 Feb 2021 Location: Kent Posts: 4 |
If I pay you can you come and do mine? Lol I’m partially sighted and have no chance. James. |
16th Feb 2021 1:36pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
Hi, James, I fitted some on mine two weeks ago?
16th Feb 2021 1:54pm |
