Home > Maintenance & Mods (L322) > Engine replacement - Range Rover 2011 4.4 TDV8 RESCUED |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7640 |
You do....smart key needs to be detected in the car and brake pedal needs to be pressed to start, in P or N.....
12th Jun 2019 9:13pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
Is there a fuel supply problem - not primed or tank level too low? |
12th Jun 2019 10:12pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3687 |
The brake pedal will probably feel rock hard, making it difficult to engage starter until you get it started and build up some vacuum pressure.
13th Jun 2019 9:35am |
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 79 |
Thanks, Baltic Blue. I've just seen that the starter motor breather tube is missing. I have no idea if its even possible to install without taking the engine back out. as I said at the beginning of this project nearly a year ago - its a jigsaw. When I said the engine is firing in my previous post; I made a mistake. they engine is turning. would the breather pipe not being connected stop it from trying to start? the brake pedal is not rock hard....not sure if that is a sign of something. |
13th Jun 2019 3:28pm |
biggirly1 Member Since: 21 Nov 2017 Location: Bicester Posts: 12 |
Have you power down trigger wire ?
13th Jun 2019 11:36pm |
The missing breather pipe on the starter won't stop it working and it's been turning anyway.
13th Jun 2019 11:51pm |
Any smoke from exhaust? Range Rover
14th Jun 2019 12:01am |
19th Jul 2019 3:29pm |
19th Jul 2019 3:44pm |
19th Jul 2019 3:48pm |
That’s cracking news after all your effort.....onwards and upwards..... and all that....
19th Jul 2019 5:38pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Amazing, congratulations you got it running!
19th Jul 2019 8:46pm |
Great that you got past the non-starting issue. Do you know if it was caused by the broken earth strap? |
19th Jul 2019 9:34pm |
20th Jul 2019 6:14am |
