Home > Technical (L322) > Adaptive Dynamics Fault light |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4245 |
Right being driver's side if sat in car I assume? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Jul 2020 11:19am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3196 |
If it is RHD. John
7th Jul 2020 11:26am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Cheers Paul - and my nuclear option repair, necessary because five or maybe more soldering repairs told me the cable had to go - is here: https://www.fullfatrr.com/forum/topic54413.html ...and I might add has been absolutely faultless. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
7th Jul 2020 1:08pm |
EK Member Since: 09 Aug 2020 Location: Scotland Posts: 7 |
First, I would just like to say thanks for all the information I have learned from this site and wish I had the knowledge to contribute. Maybe one day, but for now I'm a noob.
9th Aug 2020 5:08pm |
Will have a look at my repair, very easy with a few bits off ebay:
9th Aug 2020 5:16pm |
I'm reading it now Greg. Looks like an excellent and inexpensive job you have made of it. Do you think that will be my issue looking at the wires in the pics I provided?
9th Aug 2020 5:21pm |
yes and a further look at your pics i can see a new revised wire has been spliced in. However, following the wire from the damper, there are two crimps. Undo all the tape around the original loom wire after the crimps. You may find a break here.
9th Aug 2020 5:26pm |
Going to give it a go shortly. Might be a bit of a bodge until the parts you listed turn up in the mail.
9th Aug 2020 6:19pm |
No joy I'm afraid. I checked along the length of both cables as best I could.
9th Aug 2020 8:30pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7637 |
I’ve read a few posts about those failing, but the wiring doesn’t have to turn with the strut like the front ones, so not as common.
9th Aug 2020 9:27pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 350 |
I know we're in COVID times, but if there's no obvious damage then the quickest way to at least narrow down which of the 4 corners is your problem would be to get the fault codes read, whether at a garage or someone local with an IID or other suitable tool. Presumably to just read the fault codes a much cheaper code reader would suffice, and still very handy to have if you don't want/have a full on (expensive) IID type tool. |
11th Aug 2020 9:33pm |
neilly Member Since: 06 Oct 2019 Location: Oxon Posts: 74 |
I had the adaptive dynamics fault appear on the dash, read it with diagnostics.
12th Aug 2020 3:48pm |
All fixed now by a local garage.
14th Aug 2020 11:47pm |
I’ve popped my cherry on this! Bling it went! IID out. Right front (drivers). Wire had parted from clearly a previous solder job. Turret off, wires stripped and soldered. Cleared fault. Sorted
15th Aug 2020 3:13pm |
