Home > Technical (L322) > Air suspension ECU module not working and system is inactive |
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 |
Does it simply come up with the message 'suspension lowered' and the lights on the suspension control button stay unlit? If so...and I hope it is this, then you might just need to replace a relay in the fusebox in the boot.. |
26th Dec 2020 9:51pm |
Mimic Member Since: 18 Dec 2016 Location: London Posts: 8 |
I was also hoping that it was a fuse but after taking it to the repair center they said the air suspension ecu wasn’t working after testing. The control buttons don’t work or light up and the suspension is lowered to the bottom.
27th Dec 2020 1:23am |
No, not a fuse! A relay! Your symptoms sound exactly like mine were....and for the cost of a relay (£6.00) it has to be worth a shot..
27th Dec 2020 1:30am |
27th Dec 2020 1:41am |
Thanks, will check on the relay.
27th Dec 2020 1:48pm |
They said the relays were working. Guess it’s the unit. Found a working second hand unit, will give that a try. Secondhand one should would be ok to install? |
28th Dec 2020 11:42am |
Ah ok...hopefully your new unit will sort things! I know very little about which units require coding in..fingers crossed it will just be a straight swap! |
28th Dec 2020 10:52pm |
Struggling Member Since: 11 Apr 2021 Location: Lincolnshire Posts: 2 |
What happened was it relay or ecu
19th Nov 2023 11:24am |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 246 |
I've got my suspension ecu to replace as well ....how much trouble did you find it to do ? 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
22nd Nov 2023 6:26pm |
