Home > Technical (L322) > Air suspension ECU module not working and system is inactive
Mimic
Hi,
I've been having an issue with my air suspension ECU, and I was told it needs to be replaced by my technician. This is for a Range Rover L322 2008 model. The module I need to replace they said was RQT500181.
I wanted to know if I need to buy a brand new module or can I use a used one? I was told due to the programming it won’t be accepted by the vehicle system, but just wanted to check.
Thanks
Post #577230 26th Dec 2020 2:14pm
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Does it simply come up with the message 'suspension lowered' and the lights on the suspension control button stay unlit? If so...and I hope it is this, then you might just need to replace a relay in the fusebox in the boot..
Post #577288 26th Dec 2020 9:51pm
Mimic
I was also hoping that it was a fuse but after taking it to the repair center they said the air suspension ecu wasn’t working after testing. The control buttons don’t work or light up and the suspension is lowered to the bottom.
Is it possible to repair the existing ecu unit?
Post #577303 27th Dec 2020 1:23am
Zeb
No, not a fuse! A relay! Your symptoms sound exactly like mine were....and for the cost of a relay (£6.00) it has to be worth a shot..
Have a read here...
https://www.powerfuluk.com/range-rover-l32...nd%20side.
Post #577304 27th Dec 2020 1:30am
Zeb
Have a read here...it is a known fault...but not known by some garages/ specialists so it seems, who then diagnose it as a 'hard fault' because no lights are showing, when in fact it is just the relay.
Post #577305 27th Dec 2020 1:41am
Mimic
Thanks, will check on the relay.
When I start the vehicle it shows ‘Terrain response system faulty’. It doesn’t give the message suspension inactive or suspension faulty. The service center for my vehicle recently did a repair on my alternator and replaced one of the height sensors.
Will get the relays checked for now but if it isn’t the relay, will a secondhand ecu from another vehicle work on mine?
Post #577353 27th Dec 2020 1:48pm
Mimic
They said the relays were working. Guess it’s the unit. Found a working second hand unit, will give that a try. Secondhand one should would be ok to install?
Post #577462 28th Dec 2020 11:42am
Zeb
Ah ok...hopefully your new unit will sort things! I know very little about which units require coding in..fingers crossed it will just be a straight swap!
Post #577578 28th Dec 2020 10:52pm
Struggling
United Kingdom 2007 Range Rover Autobiography TDV8 Barolo Black
What happened was it relay or ecu
Got same problem
Post #678268 19th Nov 2023 11:24am
will308f
United Kingdom 2008 Range Rover Vogue TDV8 Orkney Grey
I've got my suspension ecu to replace as well ....how much trouble did you find it to do ? 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #678519 22nd Nov 2023 6:26pm
