Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4245 |
I’d just leave well alone. Lots of us have that code to no ill effect Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
12th Oct 2019 8:18am |
I had mine replaced recently at Rovertune at minimal cost as part of a wider list of jobs being carried out. They replace a lot apparently on a regular basis so have the experience and tools to do it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Oct 2019 8:15am |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 181 |
First its a thanks to everyone's contribution on this topic and I am pleased that I found it. I've had mine RR for three years without the dreaded message but it appeared a few weeks ago. What was pleasing in a way is that I'm not the only one and that members have the knowledge and are prepared to enlighten others! During my first service at an Ind. garage. I had a EGR sensor fitted - Dec 2017. The following year the service was done but they reported the P040D-00 error code and two sensors were fitted as they didn't get a regeneration after they fitted the first to the EGR. I looked back at their invoices to see these comments this week and the 10 hrs plus sensor costs. In fairness I was told "we have NOT done this before" and I didn't get a quote from them either. What may be of interest to everyone was that they removed the nearside front wheel arch cover and removed fuel filter and other bits (I'm no engineer) to do it. Just wondered if that seemed to be helpful to anyone?
26th Sep 2020 12:05pm |
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 191 |
Dave, many thanks. Like you, retired, not many long runs. Wow 10hrs, my Indy charges £50 per Plus how to decide which sensor to fit. More thinking to be done. 2013 SDV8 4.4 SE Luxor.
1st Jun 2022 3:34pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3685 |
Like many others I have had this fault code showing for years.
1st Jun 2022 3:52pm |
So can anyone put an estimate for a garage to fit one. Nylands said 10 hours plus. That’s prohibitive. Can I do it myself .? 2013 SDV8 4.4 SE Luxor.
1st Jun 2022 5:26pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
I’ve just been down this route… there is a wiki section on replacing it.. it’s a rotten job, and mine broke off. So no chance of actually replacing it, without removing the actual manifold. I have a new sensor, and when plugged in, and left dangling by the manifold, it obviously clears the code alarm… however it doesn’t get hot there, and doesn’t do it’s job. So I decided to experiment, and heat up the sensor, and measure the resistance at hot temps. Took it all the way to red hot, and got a max resistance of 650 ohms. So I ordered a 650ohm resister, which I plan to fit on the wires that feed the knackered sensor. Ie cut the wires off, fit a resistor, and drive it. That sensor will then reads hot exhaust, and should allow a regeneration, when other factors allow.. ie other sensors, speed etc. when I get the thing fitted I will report back. For what it’s worth, I’m not planning on removing the manifold as it looks a hell of a bad job, and will no doubt give me another problem… |
1st Jun 2022 9:51pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
It may well be possible to get a spark eroder in there, that'd get enough of it out for you to clean the threads up. You'd need to drop the exhaust off the manifold so you're not pushing the waste into the CAT / DPF though. |
1st Jun 2022 10:11pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
I had my last FF done by LR some 3 years ago and the list hours was quoted as one hour?
1st Jun 2022 10:28pm |
If it was a job I was doing, I'd cut off all the gubbins above the nut, heat with a small oxy-propane torch to keep the heat localised, get it cherry red, allow to cool and heat to cherry red again, then get a single hex impact socket (less chance of wear on the shoulders) on it with a 'T' bar using lots of side-to-side movement to free the threads, if it's not in the mood to move, then Plasma or spark eroder before anything is sheared off - less chance of damage to the manifold threads. |
1st Jun 2022 10:56pm |
Davidmudley Member Since: 27 Dec 2021 Location: Surrey Posts: 80 |
I just spoke to a Surrey LR main dealer who has quoted £840 (unclear of this is inc or ex VAT) but they also mentioned the worst case scenario would be if they had to take the engine out to replace the sensor.
3rd Aug 2022 9:48am |
Getting lots of penetrating oil onto it is definitely key, also a good fit six sided deep socket, not the special tool to loosen it, that’s just for fitting the new one.
3rd Aug 2022 1:48pm |
Have you called a few independent specialists? Don’t forget we now have a forum sponsor close to you just nr Liphook on the A3. www.glenrands.co.uk All LR trained technicians etc Loan cars too Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
3rd Aug 2022 4:39pm |
you can save yourself a whole lot of grief, and get a guaranteed code clear, if you use my resistor fix, as detailed above. -been working fine for a few months now. the old nut, should it break, and become loose, it will allow an exhaust 'blow' which will have to be addressed.
3rd Aug 2022 10:10pm |
